• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    New Member
    ashfaqhadi
    acaddoc.lsp virus
    7652 Views, 5 Replies
    06-04-2011 07:54 AM
    I Have problem when i open autocad 2008 & 2011
    the below message appears in the command line.
    and when ever i open the drawing from the folder there is automatically a file created in the folder named acaddoc.lsp
    can any one help me to remove this threat from the autocad software
    i have also re-installed the autocad software but the same problem is repeated again
    "AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
    AutoCAD menu utilities loaded.; error: LOAD failed: "acadapq"
    Command: COMMANDLINE
    Command: properties"
    Edited by
    Discussion_Admin
    Please use plain text.
    Re: acaddoc.lsp virus
    06-04-2011 02:25 PM in reply to: ashfaqhadi
    see my image yes is a virus
    Active Contributor
    06-06-2011 07:28 AM in reply to: ashfaqhadi
    To delete the virus,Dwg file is located in the folder, delete files in the LSP.Install the following file.
    The command line to run the program "AcdDcCLr" type .
    DWG file before starting another, if there are files in the folder, delete them LSP.
    Active Contributor
    zingero84
    05-03-2012 03:48 AM in reply to: ashfaqhadi
    Does this fix actually work?
    I am having the same problem and it's VERY ANNOYING.  I have no clue how i got this virus because I don't even have time to do anything else at work but work.
    All of my drawing file folders have the acaddoc.lsp in them.  If I delete it before opening, they is no virus wanring.  If I leave it there and open it, I get a virus warning.
    How do I permanently remove this virus from my computer?
    Active Contributor
    zingero84
    05-03-2012 03:51 AM in reply to: ashfaqhadi
    Here is my opening command line info:
    Opening an AutoCAD 2004/LT 2004 format file.
    Substituting [Arial00000034] for [Myriad Apple].
    Resolve Xref "12-013 22x34": X:\12-013 22x34.dwg
    "12-013 22x34" loaded.
    Resolve Xref "OH ELECT": X:smileysurprised:H ELECT.dwg
    "OH ELECT" loaded.
    Resolve Xref "12-013 bldg type a": X:\12-013 bldg type a.dwg
    "12-013 bldg type a" loaded.
    Resolve Xref "12-013 bldg type b": X:\12-013 bldg type b.dwg
    "12-013 bldg type b" loaded.
    Regenerating layout.
    Regenerating model.
    C:NEWDATEno function definition: ACET-AUTOLOAD2
    Command:
    Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
    or Autodesk licensed application.
    Command:
    Active Contributor
    zingero84
    05-23-2012 12:08 PM in reply to: zingero84
    I cannot get rid of this virus.
    Can someone help me out?
