Visual LISP, AutoLISP and General Customization
acaddoc.lsp virus
5 REPLIES 5
ashfaqhadi
12233 Views, 5 Replies
acaddoc.lsp virus
I Have problem when i open autocad 2008 & 2011
the below message appears in the command line.
and when ever i open the drawing from the folder there is automatically a file created in the folder named acaddoc.lsp
can any one help me to remove this threat from the autocad software
i have also re-installed the autocad software but the same problem is repeated again
"AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.; error: LOAD failed: "acadapq"
Command: COMMANDLINE
Command: properties"
Edited by
Discussion_Admin
Tags (2)
5 REPLIES 5
diagodose2009
in reply to: ashfaqhadi
see my image yes is a virus
To delete the virus,Dwg file is located in the folder, delete files in the LSP.Install the following file.
The command line to run the program "AcdDcCLr" type .
DWG file before starting another, if there are files in the folder, delete them LSP.
Mehmet Şamil DEMİRYÜREK
Bu gönderiyi faydalı buldunuz mu? Bu gönderiyi beğenmekten çekinmeyin.
Sorunuz başarıyla yanıtlandı mı? ÇÖZÜMÜ KABUL ET düğmesine tıklayın.
Linkedln
Does this fix actually work?
I am having the same problem and it's VERY ANNOYING.  I have no clue how i got this virus because I don't even have time to do anything else at work but work.
All of my drawing file folders have the acaddoc.lsp in them.  If I delete it before opening, they is no virus wanring.  If I leave it there and open it, I get a virus warning.
How do I permanently remove this virus from my computer?
Here is my opening command line info:
Opening an AutoCAD 2004/LT 2004 format file.
Substituting [Arial00000034] for [Myriad Apple].
Resolve Xref "12-013 22x34": X:\12-013 22x34.dwg
"12-013 22x34" loaded.
Resolve Xref "OH ELECT": X:OH ELECT.dwg
"OH ELECT" loaded.
Resolve Xref "12-013 bldg type a": X:\12-013 bldg type a.dwg
"12-013 bldg type a" loaded.
Resolve Xref "12-013 bldg type b": X:\12-013 bldg type b.dwg
"12-013 bldg type b" loaded.
Regenerating layout.
Regenerating model.
C:NEWDATEno function definition: ACET-AUTOLOAD2
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command:
I cannot get rid of this virus.
Can someone help me out?
”Boost
