Visual LISP, AutoLISP and General Customization
Message 1 of 6 (5,002 Views)
acad.pgp for AutoCAD LT 2011?
5002 Views, 5 Replies
06-08-2010 08:05 AM
We just loaded LT 2011 (formerly used AutoCAD 2006) and some of the commands I'm used to using are gone. I can't seem to find an acad.pgp file so that I can change "c" from 'copy' to 'circle'.
If there is no .pgp file available, how do I go about updating the keyboard shortcuts for various commands?
Deanna
Distinguished Mentor
Message 2 of 6 (5,001 Views)
Re: acad.pgp for AutoCAD LT 2011?
06-08-2010 08:17 AM in reply to: dlwalch
Firstly have you installed the ExpressTools.  It's an extra tick (don't go default).
In ET there is a command called AliasEdit that will open the Acad.pgp file and give you an interface.
What operating system are you using?
on my XP it's in here
C:\Documents and Settings\USERNAME\Application Data\Autodesk\ACA 2011\enu\Support
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://www.youtube.com/playlist?list=PLD9BF5D8FF70CD3DF&feature=view_all
Message 3 of 6 (4,997 Views)
06-08-2010 08:29 AM in reply to: ntellery
No, I did not install the Express tools. I was told to just go with the default installation. That should never be my choice as I like to personalize all of my commands. I am going to update my install with the Express tools and then I'll let you know how it worked out. Thanks for the info!
Deanna
Message 4 of 6 (4,999 Views)
06-08-2010 08:59 AM in reply to: dlwalch
I meant the acad.pgp is here
Message 5 of 6 (4,992 Views)
06-08-2010 11:26 AM in reply to: ntellery
Thanks! Updating my .pgp file worked. Glad to have my old commands available at my fingertips!
Deanna
Active Member
abouzane
Message 6 of 6 (3,918 Views)
02-15-2011 08:36 AM in reply to: dlwalch
you rock.
needed that user subfolder in the **** support file seach path.
lame.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
