• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    *Expert Elite*
    Re: Windows is 32 or 64?
    02-17-2013 02:21 PM in reply to: aqdam1978
    Hi Abbas,
    glad you got a solution
    Henrique
    Please use plain text.
    Moderator
    Alexander.Rivilis
    02-17-2013 10:37 PM in reply to: hmsilva
    What about many years known function:
    (defun is64 ()
     (vl-load-com)
     (> (strlen (vl-prin1-to-string (vlax-get-acad-object))) 40)
    P.S.: Version of Windows (i.e.. x86 or x64) and version of AutoCAD can be different. For example AutoCAD 2007 x86 can be installed and work on Windows x64 (XP/Vista/Win7). Version of arx-files dependent of AutoCAD version and not of Windows version.
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    *Expert Elite*
    02-18-2013 01:15 AM in reply to: Alexander.Rivilis
    Alexander. thank you, "many years known function"
    but I did not know ...
    Henrique
    Moderator
    Alexander.Rivilis
    02-18-2013 01:21 AM in reply to: hmsilva
    This is because you do not use Search. :smileywink:
    *Expert Elite*
    02-18-2013 01:33 AM in reply to: Alexander.Rivilis
    not correct, I often use "search" is a very good tool and is my first choice... :smileywink:
    Henrique
    Distinguished Contributor
    02-18-2013 05:26 AM in reply to: Alexander.Rivilis
    what is you opinion about reading from registry?
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Environment\PROCESSOR_ARCHITECTURE
    02-18-2013 05:57 AM in reply to: aqdam1978
    Inspecting (getvar "PLATFORM") will not work, as you have found. You must use (getenv "PROCESSOR_ARCHITECTURE") for inspecting the architecture of the running AutoCAD. See ISX64.LSP here:
    http://www.manusoft.com/software/freebies/lisp.html
    Owen Wengerd
    ManuSoft
    Moderator
    Alexander.Rivilis
    02-18-2013 06:03 AM in reply to: aqdam1978
    PROCESSOR_ARCHITECTURE allow check Windows architecture (x86/x64) but not a AutoCAD architecture. As I wrote above this is not the same thing.
