Message 1 of 18 (430 Views)
Windows is 32 or 64?
430 Views, 17 Replies
02-03-2013 12:49 PM
I have my own acaddoc.lsp file, I need to load some arx file depends on Windows version:
acaddoc.lsp:
;if AutoCAD is 32bit:
(arxload "DOSLib19.arx")
;if AutoCAD is 64bit:
(arxload "DOSLib19x64.arx")
So, how can I find out the OS version and implement this lisp file?
Message 2 of 18 (426 Views)
Re: Windows is 32 or 64?
02-03-2013 01:06 PM in reply to: aqdam1978
aqdam1978
try
(getvar "PLATFORM")
Henrique
Message 3 of 18 (418 Views)
02-03-2013 01:40 PM in reply to: aqdam1978
aqdam1978,
with the
(getvar "PLATFORM");;for Windows 7 I get
"Microsoft Windows NT Version 6.1 (x86)"
for 32bit and
"Microsoft Windows NT Version 6.1 (x64)"
for 32bit, so to implement your arxload, using your previous code, perhaps something like
(setq str (getvar "PLATFORM"))
(setq pos (vl-string-position (ascii "(") str))
(setq osver (substr str (+ pos 2)))
(if (= osver "x86)")
);; if
perhaps not the most elegant way to do it, but will do the trick.
hope that helps
Henrique
Message 4 of 18 (415 Views)
02-03-2013 01:58 PM in reply to: hmsilva
Hi hmsilva,
Thank you for your code,
I just change the 3rd and 4th line:
;;----- gets OS version x86 or x64 ---------------------
(setq osver (substr str (+ pos 2) 3))
(if (= osver "x86")
);; if
Message 5 of 18 (412 Views)
02-03-2013 02:03 PM in reply to: aqdam1978
You're welcome, aqdam1978
glad you got a solution
Henrique
Message 6 of 18 (404 Views)
02-03-2013 02:56 PM in reply to: aqdam1978
aqdam1978,
just another way to load the arx files, or other file types, is first to be sure that the file exists,
and then load it, in this way there will be no error related to the load, and canceling the rest of your code,
in the example below,  the file to load is in a suport directory, if not, we have to provide the full path,
(if (and (= osver "x86")
	 (findfile "DOSLib19.arx"));; if osver is 32bit and the arx file is found then
  (arxload "DOSLib19")
  );; if
(if (and (= osver "x64")
	 (findfile "DOSLib19x64.arx"));; if osver is 64bit and the arx file is found then
  (arxload "DOSLib19x64")
);; if
or another way
(cond
  ((and (= osver "x86") (findfile "DOSLib19.arx"));; if osver is 32bit and the arx file is found then
  ((and (= osver "x64") (findfile "DOSLib19x64.arx"));; if osver is 64bit and the arx file is found then
);; cond
hope that helps
Henrique
Message 7 of 18 (399 Views)
02-03-2013 04:56 PM in reply to: hmsilva
Hi Henrique,
Thanks for your ideas,
I change the program to:
;;----- LOAD your app depends on OS version (x86 or x64) -----------
(defun C:app_load_by_OS(/ str pos OSVer x86app x64app)
(setq
;------ Your app in both version (x86 or x64) ---------------------
  x86app "DOSLib19.arx"
  x64app "DOSLib19x64.arx"
);;setq
(if (= osver "x86")
    (progn
		(if (findfile x86app) (arxload x86app)
		(alert (strcat "Error:\nfile: " x86app "\nNot found!")))
    );;progn
;;else if
	(if (= osver "x64")
		(progn
			(if (findfile x64app) (arxload x64app)
			(alert (strcat "Error:\nfile: " x64app "\nNot found!")))
		);;progn
	;;else
		(alert "Error:\nYour system not supported!")
	);;if x64
);;if x86
Abbas
Message 8 of 18 (372 Views)
02-04-2013 01:07 AM in reply to: aqdam1978
Glad I could help
Henrique
dgorsman
Message 9 of 18 (360 Views)
02-04-2013 07:32 AM in reply to: aqdam1978
Operating systems don't change day to day, week to week, or even month-to-month.  Create your own registry key and set it once with "x32" or "x64" (or "x128" - future compatibility...), then read it when checking using (vl-registry-read...).  You can also use it for other applications.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Message 10 of 18 (324 Views)
02-17-2013 02:14 PM in reply to: hmsilva
Hi Hmsilva,
(getvar "PLATFORM") did not work on some windows OS's.
it is better to use this code:
(defun c:GetOSArchitecture  (/ WMI meth1 meth2 result)
  (vl-load-com)
  (cond ((and (setq WMI (vlax-create-object "WbemScripting.SWbemLocator"))
              (setq meth1 (vlax-invoke WMI 'ConnectServer nil nil nil nil nil nil nil nil))
              (setq meth2 (vlax-invoke meth1 'ExecQuery (strcat "Select * from Win32_" "OperatingSystem")))
              (vlax-for itm  (vlax-get (vlax-invoke meth2 'ItemIndex 0) 'Properties_)
                (if (eq (vlax-get itm 'name) "OSArchitecture")
                  (setq result (vlax-get itm 'value)))))))
  (mapcar 'vlax-release-object (list meth1 meth2 wmi))
  result
Abbas
You are not logged in.
Ask the Community
