Hi Everyone,
This may be super easy, but I want to put the list of open drawings (like the window tab on the menubar has) onto the ribbon? Is this possible?
Angie
Solved by dbroad. Go to Solution.
@angiegauthier wrote:... I want to put the list of open drawings (like the window tab on the menubar has) onto the ribbon? Is this possible?
The ribbon already has one on the view tab. . Don't forget that you also should have qvdrawing on the status bar as well.
yep. that's what I need. I knew it was super easy.
We've moved from ACAD 2006 to 2013, so I'm still getting used to the ribbon.
thanks.
