Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Joel Roderick
Re: Why does Autodesk ignores the LISP community?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-26-2004 01:13 PM in reply to:
JeremyD
Jason,
You may find the AU class material I did to be useful. It walks you through
step by step on creating a project. Not sure if they still have them up on
the website, so if you need it, let me know.
Joel Roderick
"Jason Piercey" wrote in message
news:412c8911$1_2@newsprd01...
> I've tried it, and find it very confusing to be honest.
> Haven't been able to complete a single simple project
> with it as of yet. Perhaps I am just not smart enough
> to figure it out.
> "James Maeding" wrote in message
> news:seeoi0t56r24jolb1mrsjgocfjumjti5j9@4ax.com...
> > Have you tried ObjectDcl? Its a Lisper's dream.
*Jason Piercey
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-26-2004 01:32 PM in reply to:
JeremyD
Hi Joel,
I'd like to take a look at it, if you don't mind.
Off the top of my head, some trouble I had with it
was lack of documentation, and why on earth you
need *all* of your functions defined like a command
(with the c: prefix) That just doesn't make any
sense to me.
Thanks for the offer.
Autodesk Discussion Group Facilitator
"Joel Roderick" wrote in message
news:412e4453_1@newsprd01...
> Jason,
through
on
> Joel Roderick
*Martti Halminen
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-27-2004 02:07 AM in reply to:
JeremyD
David Allen wrote:
> yes a problem. A new customization enviroment is the reason I do not switch from autocad to revit. I don't want to
> loose all of my tools I have built up over the years. The same thing would happen if autodesk ditched lisp for some new
> format.
> Now if VBA was more commandline friendly then maybe it would be easier to use.
> Martti Halminen
> |>> |>The most intelligent thing AutoDesk could do regarding
> |> > |>AutoLisp/VisualLisp would be to throw it away and replace it with a
> |> > |>full-size CL from one of the commercial vendors, with a compatibility
> |> > |>package to allow old AutoLisp code to run.
> |> > |>- Whether this is politically possible is another question.
> |>Not a problem, the command line behaviour could stay the same
> |>regardless of the Lisp implementation behind. The compatibility package
> |>would be the default interface, so a casual user wouldn't notice the
> |>difference.
If you have the source code for your tools, all it would require would
be re-compilation; building a source-code compatibility mode in CL would
be quite easy, any competent CL programmer could do it. Building a
system which could read .vlx files and other
compiled/encrypted/obfuscated stuff would be possible, but would need
far more work and intimate knowledge of VisualLisp etc implementation
internals.
*David Allen
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 08:23 AM in reply to:
JeremyD
Like you said "If" you have the source.
So does lisp, arx, vlx and the rest run in revit? No. Its a totally different enviroment.
If (when) autodesk changes its customization enviroment again, legacy arx programs will break again. Some lisp will
also no longer work.
Martti Halminen
|>> format.
|>> Martti Halminen
|>> |>difference.
|>internals.
David
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 09:37 AM in reply to:
JeremyD
Hi The documentation has been improved opon. There is an online example section. All the examples are installed with ObjectDCL. There is an intelligent help system that displays the help information through the selected dialog box or control. It will display correctly formated code for the selected object. Joel Roderick Wrote a course for Autodesk Univercity that we are distributing with ObjectDCL. It does and excellent job with teaching a first time user. We also have a manual written by Jim Short that is evalable for download as well from our web site. The new version 3.0 of ObjectDCL has no lack of documentation.
The C: prefix is required because of a shortfall in the ObjectARX programming interface that we cannot work around. There are two ways to activate a defun from ObjectARX and one of them requires the C: prefix to work, the other does not. But for simplification, we made it so both settings require the C: prefix. We would remove it if we could, but unfortunatly we can't.
*Joel Roderick
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 09:39 AM in reply to:
JeremyD
Jason,
I put a copy of the paper here:
www.globaldialog.com\~jroderick\CP21-3.zip
The c: issue is explained in the help file:
"There are two similar styles that can be used to program AutoLisp code to
handle the ObjectDCL events. But first, to answer a question some of you
may have, you will notice that ObjectDCL calls its events as C:xxx defun'd
functions. This is done because of the limitation ObjectARX imposes on
mechanisms to call AutoLisp functions from some ObjectARX dialog boxes.
Rather then setup ObjectDCL to defun some events as C:xxx and others as xxx,
C:xxx is used as the standard. The first programming style defines all the
event defun's inside the main defun. This allows the program to be created
free of global variables. The second style allows global variables to be
used instead to organize information between the main defun and the event
defun's."
If you look at my example in the AU paper, I actually localize the event
c:defuns. I tend to be anal about stuff like this
When I was doing the CDG thing, I used ObjectDCL for CDGPurge. Since I have
dropped the website I have been thinking of just releasing the code as an
ObjectDCL example and letting people have fun with it.
HTH,
Joel
news:412e48be_1@newsprd01...
> Hi Joel,
> sense to me.
> > Jason,
> through
> on
> > Joel Roderick
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JeremyD
If the arx spec's change, the we have to change our code to suit. We usually have to create a new C++/ObjectARX project for every second new release of AutoCAD.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 09:43 AM in reply to:
JeremyD
Hi, we have been supporting ObjectDCL for AutoCAD from R14 through to 2005. R14 is no longer supported, but we have arx files for all versions of AutoCAD otherwise. The arx distribution files are free to distribute so getting a copy from us will not be problem.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 09:50 AM in reply to:
JeremyD
When 2004 came along, the C++ compiler went from VC++ 6.0 to VC++ .Net. This meant that to be able to compile for 2004 we had to get the next version of MS VC++ and compile the code in that version. The only changes we needed to make we forced by Microsoft's new .Net and windows XP looking controls. We had to slightly modify a few of our controls so the painted properly in Windows XP. The only change we had to make because of AutoCAD was the option/config tabs. Because our product mainly works with MFC, ObjectDCL is barley affected, if at all when a new version of AutoCAD comes out.
*Luis Esquivel
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
08-30-2004 10:21 AM in reply to:
JeremyD
Hi Chad,
The concern it will be about the long run.... what if ODCL is abandoned?
