In Autocad 2015 some lisp auto loads (acaddoc.lsp, appload, cui) and some don't, some lisp runs after a manual load and some don't. I use a DimNote.lsp from the Cadalyst tips (attached) which runs fine in 2012 and now it returns this message: "Command: DN ; error: quit / exit abort". Have checked files that don't work in the VLIDE and have not found any errors yet. Has there been some lisp requirement added like the (vl-load-com) was a while back?
Looking at the error message an the LISP code, I think the error is raised by the (exit) calling here:
(setq DCL_ID (load_dialog "dimnote.dcl")) (if (not (new_dialog "dimnote" DCL_ID)) (exit) )
Is the dimnote.dcl file in a search path ?
Yes it is. Won't attach as a .dcl though, I changed the extension.,
