Vla-Insertblock and seeing the block preview during insert
1 REPLY 1
Redraiderr2009
1429 Views, 1 Reply
Is there a way to see the block preview with my cursor using vla-insertblock? A lot like the command -insert function
	(setq PlantBlockObject
		(vla-insertblock
			(vla-get-modelspace (vla-get-activedocument(vlax-get-acad-object)))
			(vlax-3d-point (trans (getpoint) 1 0))
                        (strcat pBlockPath pBlockName ".dwg")
			xBlockScale
			yBlockScale
			zBlockScale
			(angle '(0 0 0) (getvar "ucsxdir"))
		);_end insert block
	);_end setq
Tags (1)
1 REPLY 1
_gile
in reply to: Redraiderr2009
If you really have a good reason not to use the command function:
(command
  "_.insert"
  "X"
  xBlockScale
  "Y"
  yBlockScale
  "Z"
  zBlockScale
"_rotate" 0.0 )
You can use grread, but you will loose the object snaps:
       (vla-insertblock
	 (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
	 (vlax-3d-point '(0. 0. 0.))
	 xBlockScale
	 yBlockScale
	 zBlockScale
(while (and (setq gr (grread T 4 0)) (/= (car gr) 3))
  (vla-put-InsertionPoint PlantBlockObject (vlax-3d-point (trans (cadr gr) 1 0)))
Gilles Chanteau
GileCAD
GitHub
”Boost
