Visual LISP, AutoLISP and General Customization
Visual lisp v autolisp
4 REPLIES 4
agruno
113 Views, 4 Replies
how to write following Vlisp command in autolisp
(vla-item *modelspace* i)
*modelspace* is activedrawing modelspace
4 REPLIES 4
in reply to: agruno
Hi, "agruno" In autolisp you have to prompt for (vl-load-com) Regards, > how to write following Vlisp command in autolisp > > (vla-item *modelspace* i) > *modelspace* is activedrawing modelspace
in reply to: agruno
Assuming "i" represents an index number, something like this. Not much testing, but I think it works. ;; 2/20/2004 ;; argument idx: a positive integer starting at zero ;; returns the ename of object at idx position (defun test ( idx / ent elst cnt ) (setq ent (entnext)) ;first object (setq cnt -1) (while (/= idx cnt) (setq ent (entnext ent)) (setq elst (entget ent)) (if (and (not (wcmatch (cdr (assoc 0 elst)) "ATTRIB,VERTEX,SEQEND")) (eq "Model" (cdr (assoc 410 elst))) ) (setq cnt (1+ cnt)) ) ) ent ) ;end Index number (vla-item ) returns a primary vla-object. So to do the same thing with entnext, filter out the sub-entities it returns and check the item is in model space. Joe Burke "agruno" wrote in message news:32712965.1077263878867.JavaMail.jive@jiveforum2.autodesk.com... > how to write following Vlisp command in autolisp > > (vla-item *modelspace* i) > *modelspace* is activedrawing modelspace
agruno
in reply to: agruno
Thank you very match
in reply to: agruno
You're welcome. I should add, there's no error checking in that program. For instance, it will error if you pass an index number larger than the number of objects in model space. It's only intended to demonstrate a possible solution to the question you asked. Joe Burke "agruno" wrote in message news:9957823.1077280049900.JavaMail.jive@jiveforum1.autodesk.com... > Thank you very match
”Boost
