New AC new problem!
Does anybody out there know of, or have a lisp that switches back on Selection Preview i.e. thickens and higlights lines when you hover over them?
I don't know why, but they are always unticking the boxes.
Thanks in Advance.
(setvar "SELECTIONAREA" 1) ; <= Use to switch on
(setvar "PREVIEWEFFECT" 2) ; <= Use for the effect that you described.
@TrevN wrote:How do these help when the options are turned off radomly?
Nothing turns off randomly... You're likely to either have found a bug in the application, or more likely to be experiencing the result of poorly coded custom LISP routines which fail to restore original settings upon exit/error.
In order to determine when these changes are occuring, perhaps it would be prudent to register a SysVar Reactor which filters for your desired System Variable(s), so that you're notified immediately following a change to the problem System Variable(s).
Hope this helps!
"How we think determines what we do, and what we do determines what we get."
