Hi All,
I have this code w/ which I can open up Block Library Blocks for editing. We have R2012 installed w/out VBA.
Our MIS department is impossible to deal with. We have this new fangled permission hysteria so I cannot install VBA myself.
Is there any other way to open up my blocks? See the last two lines: What I can I do instead?
(defun C:OpL () (prompt "...Open Library Block or Xref...")(terpri)
(setq a (entsel)) (setq b (car a )) (setq c (entget b)) (setq d (assoc 2 c))
(setq e (cdr d)) (setq ff (strcat e ".dwg")) (setq PP (findfile FF))
(setq opath (strcat "acadapplication.documents.open \""PP"\""))
(command "vbastmt" opath))
Thank you,
GS
Solved by lando7189. Go to Solution.
Use Visual LISP to access the AutoCAD model:
(vl-load-com)
(vla-open (vla-get-documents (vlax-get-acad-object)) pp)
-- Lanny
