Visual LISP, AutoLISP and General Customization
Value must be positive and nonzero.
6 REPLIES 6
andrew.nao
1877 Views, 6 Replies
im trying to make a item balloon that counts up from the last ballon
starting from 1
however i get this error
what am i doing wrong?
(defun C:itmbln ( / Scale Radius Po Pe Pm Txt)
(setvar "CMDECHO" 0)
(setq curlayer (getvar "CLAYER"))
(while
(setq Scale (getvar "DIMSCALE")
Radius (* 0.1875 Scale)
Po (getpoint "\nStart of Leader: ")
Pe (getpoint Po "\nEnd of Leader: ")
Pm (polar Pe (angle Po Pe) Radius))
(command "line" Po Pe ^C^C)
(command "circle" Pm Radius)
(Setq Txt "1")
(command "text" "M" Pm 0 txt)
(setq txt (1+ txt))
(princ)
) ; end
6 REPLIES 6
EC-CAD
in reply to: andrew.nao
You are trying to 'increment' a string.
(Setq Txt "1"); here Txt becomes 'type' STR, a string
(command "text" "M" Pm 0 txt); this line is OK
To 'increment' that text... after you apply it, do:
(setq Txt (atoi Txt)); make Txt (str) into an integer
(setq txt (1+ txt)); increment the integer
(setq Txt (itoa Txt)); make it a string again for next loop
Bob
andrew.nao
i did that and i got this error
error: bad argument type: numberp: "1"
so i changed some things up and it works the first time but keeps asking me for the next number
so im missing something else
here is the new code
(while
(command "circle" Pm Radius) ; draw circle
(Setq Txt (getint "\nEnterNumber: "))
(* Scale (getvar "DIMTXT")) 0 (itoa txt))
(setq txt (1+ txt))
(princ)
) ; end
sorry i cant get it to show formatted Edited by: andrew.nao on Oct 13, 2008 6:31 PM
I think you may want to format it something like this.
Mel
{code:lisp}
(initget 7)
(Setq Txt (getint "\nEnter Number: "))
(while (and(setq Po(getpoint "\nStart of Leader: "))
(setq Pe(getpoint Po "\nEnd of Leader: "))
(command "line" Po Pe "")
(command "text" "M" Pm (* Scale (getvar "DIMTXT")) 0 (itoa txt))
(setq txt (1+ txt))
(princ)
{code}
jevers
By the way, Mel, how did you generate that text formatting?
Wrap the code in:
{code:lisp
{code}
I left off the first closing brace so it displays
in the web forum. (hopefully)
Mel
By
formatting?
andrew.nao
thanks mel this did the trick
”Boost
