VBA /LISP Routine to export mtext from multiple drawings
3 REPLIES 3
Joshlieu
758 Views, 3 Replies
I am new to CAD automation (LISP/VBA) but was wondering if someone could point me in the right direction...
We store a "Bill of Materials" list as an MText in many drawings. I will ultimately use this list in excel. Here's what I need to do:
-Select the Mtext in a drawing which contains the string "Bill of Materials"
-Write the contents of the Mtext to a text file
-repeat the process for every drawing in a particular folder, each time appending the text to the bottom of the text file.
any help would be totally appreciated!!!
josh
3 REPLIES 3
Hallex
in reply to: Joshlieu
This will get you started
Just change initial folder name for Browser
and name of existing text file
This is the VBA project - you can easily
rewrite it on Lisp
And also check all references accordingly to your
Acad configuration before
~'J'~
Joshlieu
Thanks a bunch!
Hallex
You're welcome
~'J'~
”Boost
