Visual LISP, AutoLISP and General Customization
*Picklesimer, Chris
Message 1 of 3 (86 Views)
Using SSGET With Variable Names
86 Views, 2 Replies
08-29-2000 12:17 PM
I want to put blocks of the same name into a selection set. I will do this
for each block in my dwg. I get the block names from TBLSEARCH and then
store each name in a variable called MyBlock. I tried the following
unsuccessfully:
(setq ss1 (ssget "X"'((0 . "INSERT")(2 . MyBlock))))
How can I do this using a variable for the block name?
Chris
*CADDee.com
Message 2 of 3 (86 Views)
Re: Using SSGET With Variable Names
08-29-2000 12:31 PM in reply to: *Picklesimer, Chris
Try the following:
(setq ss1 (ssget "X" (list (cons 0 "INSERT")(cons 2 MyBlock))))
James Dee
www.caddee.com
Chris Picklesimer wrote in message
news:96F8829230CBDE1C496671C3AD8694CB@in.WebX.SaUCah8kaAW...
> unsuccessfully:
> Thanks
> Chris
*Picklesimer, Chris
Message 3 of 3 (86 Views)
Re:
Thanks James! That did it.
Chris
CADDee.com wrote in message
news:C7EAB75A6890C1065061B99EA9AE64D6@in.WebX.SaUCah8kaAW...
> Try the following:
> James Dee
> www.caddee.com
this
> > unsuccessfully:
> > Thanks
> > Chris
You are not logged in.
Announcements
Need installation help?
Ask the Community
