We need create about 400 drawings, I have a excel file which have drawing number and all the information for title block.
I hope can have a lisp which can automatic creat drawings, the drawing names will from a excel file.
and each drawing title block also filled with data from the excel.
I`s possible to do that?
Thank very much for help.
Bin
If the final purpose is to create same drawings except the title block, you may check the old post below:
http://forums.autodesk.com/t5/AutoCAD-2007-2008-2009/Automate-Autocad-and-excel/m-p/2559945
Hello 3Wood,
Thank very much for your idea, but this lisp looks will use for PLOT hundreds drawings, which including some variable information on each drawing. However what I need is CREAT hundreds of drawing with deferent names, but all the drawings have same type of title block, basically I can copy and paste hundreds times to make hundreds drawings, but I hope can find a fast way to do this job.
Thanks again.
Bin
Hi Bin,
It won't be hard to add a small function so that EXCELPLOT can make hundreds copies of the same file with the name from your excel file.
Just following steps below:
1. Download the latest EXCELPLOT.zip and extract it to a folder.
2. Save your excel file contains the drawing list to a txt file
3. Revise the code below if the drawing name column is not the first column in your excel file. For example, if the drawing name is in column B, then change 0_0 to 0_1 in the code below. You can also change the directory in the code as your preferable folder.
Save the code as your own ExcelPlot_Cmd.lsp
(command "saveas" "" (strcat "c:\\users\\" (getvar "loginname") "\\My Documents\\" 0_0 ".dwg") )
4. Now follow the instruction in the link below to create hundreds of drawings.
https://sites.google.com/site/cadkits/home/excelplot
Select the lsp file in Step 3 when it pops out a dialogue asking "Please select the plot setting file:"
I have tested on my computer and it works well.
