HI,
I see your older post.
Did you ever find that lisp that works to un-bind files?
I have tried the lisp included earlier in this post, it seems to run, but I don't know where it's writing the files out to. Did you have luck with it.
Actually the code in the post did not work, it gave me an error as follows:
Command: UNBIND
Loading ...; error: extra cdrs in dotted pair on input
I'm not a programmer, just a hack user, so I don't know what its telling me.
I did find the following which did work, but again no idea where it's writing the output
;;;==UNBIND.LSP=====================================================
;;; This program "unbinds" bound xreferences
;;; removing the bound items and recreating the original file
(prompt "\nUNBIND\nLoading ...")
(defun C:UNBIND (/ BLCK BLK_NAME EXPR WBLOK)
(setq EXPR (getvar "expert"))
(setvar "EXPERT" 4)
(setvar "CMDECHO" 0)
;;; Check to see if AI_UTILS is loaded, If not, try to find it,
;;; and then try to load it.
(cond
( (and ai_dcl (listp ai_dcl))) ; it's already loaded.
( (not (findfile "ai_utils.lsp")) ; find it
(ai_abort "SPECIAL"
(strcat "Can't locate file AI_UTILS.LSP."
"\n Check support directory.")))
( (eq "failed" (load "ai_utils" "failed")) ; load it
(ai_abort "SPECIAL" "Can't load file AI_UTILS.LSP"))
(command "-layer" "on" "*" "thaw" "*" "unlock" "*" "S" "0" "")
(setq blk_list (ai_table "block" 14)) ; no anonymous, Xrefs or
; Xref dependents.
(setq rep 0)
(repeat (length blk_list)
(setq BLCK_NAME (nth rep blk_list))
(progn
(if (wcmatch BLCK_NAME "*$#$*");bound block
(progn
(setq head (substr BLCK_NAME 1 (str_pos "$" BLCK_NAME))
whead (strcat head "*")
fname (substr head 1 (- (strlen head) 1))
(setq flist (list '(-4 . "<OR")
(cons 8 whead)
(cons 2 whead)
(cons 6 whead)
(cons 7 whead)
(cons 3 whead)
'(-4 . "OR>")
(setq xsels (ssget "X" flist))
(command "wblock" fname "" "0,0" xsels "")
(command "purge" "a" "" "n")
);end progn
);endif
);end progn
(setq rep (+ 1 rep))
);end repeat
(setvar "EXPERT" EXPR)
(prompt "\n")
(prompt "\nWBlocking complete.")
(princ)
(defun STR_POS (schar sstring / )
(setq ptr (strlen sstring)
ctr 0
fnd nil)
(while (and (< ctr ptr)(not fnd))
(setq ctr (+ 1 ctr))
(setq fnd (or fnd (= (substr sstring ctr 1) schar)))
);end while
(setq ctr ctr)
