Toolbar lisp error
5 REPLIES 5
chase.hochstrasser
7347 Views, 5 Replies
Toolbar lisp error
Below is the name of my file and the code i put inside but this fails with the error
_appload myProg.lsp successfully loaded.
; error: bad function: "Testbar"
each time i try to load this application
myProg.lsp
***TOOLBARS
**TESTBAR
ID_1 [_Toolbar("Testbar", _Floating, _Show, 202, 163, 1)]
Tags (4)
5 REPLIES 5
Hmmmm... ...The real question is: "What the hell the content of old good MNU and MNS file is doing inside the LSP file"??? ; ))
i guess i'm confused on how to make a toolbar with buttons in autocad 3d map 2011
You can do this by two ways: 1. "MODERN": making Toolbar and Buttons with user interface (command "CUI"); 2. "ARCHAIC": making a MNS file with your content and loading it with old good "MENULOAD" command. ; )
Thanks the MNS file is what i needed to do.
Glad to help! ; )
”Boost
