Visual LISP, AutoLISP and General Customization
To-lin Lisp - Exports linetypes to a new *.lin file
5 REPLIES 5
bodhran
4972 Views, 5 Replies
Higuys,
Just wondering if anyone knows if this lisp will work on Windows 7??
We've recently upgraded to 2012 on windows 7 from 2008 on XP and i treid to use this lisp yesterday but it didn't work.
I can't remember if it write the file new lin file to the drawing file location or if it goes to the C drive.
Our IT dept. have locked off pretty much everything except our desktops so maybe that an issue!!
5 REPLIES 5
dicra
in reply to: bodhran
This lisp is working fine on win7 and AutoCad 2012,
lin file is created in my document.
I am using totalcommander, and if you open drawing from him, files will be created in folder where is drawing location.
bodhran
in reply to: dicra
That's weird! It works for me, says it creates the file but I can't find it anywhere on my pc!!
dicra
Try to search for file which was created,
Type in start search:
NEWLT.LIN
bodhran
in reply to: dicra
I did try that no file with that name on my pc!
dicra
Try with this, i  test it only once and it suppose to alert you where is your file located.
 I just added these two lines:
(setq fileloc (findfile "newlt.lin"))
(alert (strcat "Your file location: " fileloc))
And try to set  variable  REMEMBERFOLDERS to 0,
if it is set to 0 your file will be saved at the same folder where is the drawing which you opened.
”Boost
