Visual LISP, AutoLISP and General Customization
Valued Contributor
mhlr
Message 1 of 14 (419 Views)
Tile Vertical Multiple Dwgs.
419 Views, 13 Replies
06-05-2012 08:16 AM
Does anyone in the group know how to do this?:
I have multiple dwgs. opened but minimized so that only their small windows are line up down at the bottom of Autocad. I want to know if there is a way to call them all up to full screen, tiled vertically, at the same time with one command.
Thanks in advance.
M.
Distinguished Mentor
_Tharwat
Message 2 of 14 (411 Views)
Re: Tile Vertical Multiple Dwgs.
06-05-2012 10:57 AM in reply to: mhlr
The command is already existed in the menu Window -> Tile Vertically .
____________________________________________________
Get learn and learn and practice , to become experienced guy .
Valued Contributor
mhlr
Message 3 of 14 (395 Views)
06-06-2012 06:08 AM in reply to: _Tharwat
When I issue that command it DOES NOT bring all of the minimized dwgs. back up to full screen, is there a variable or setting somewhere to make that happen??
_Tharwat
Message 4 of 14 (392 Views)
06-06-2012 06:14 AM in reply to: mhlr
Use this code to maximize all drawings then use the command Tile Vertically .
(vlax-for x (vla-get-documents (vlax-get-acad-object))
  (vla-put-windowstate x Acmax)
Valued Contributor
mhlr
Message 5 of 14 (388 Views)
06-06-2012 06:19 AM in reply to: _Tharwat
Forgive me in advance!! I know your trying to help!! Could you tell me how to utilize this code? I know nothing about Autolisp or any programming language!! I know what I want to do but don't know how to make it happen!!
Thank you
*Expert Elite*
pbejse
Message 6 of 14 (385 Views)
06-06-2012 06:24 AM in reply to: mhlr
Look into vla-put-windowstate
WindowState
 acWindowState enum; read-write
 acMin
  The window is minimized.
 acMax
  The window is maximized.
 acNorm
  The window is normal (neither minimized nor maximized).
[I'm too slow......];<-----
_Tharwat
Message 7 of 14 (384 Views)
06-06-2012 06:25 AM in reply to: mhlr
It is Ok ,
1- Open Visual lisp editor by typing vlide then a new file and save the following code in the new file to a specific location and then go back to Autocad and type in the command line AP and a dialog box would appear and after that select the file that you have just created and press load .
2- finally , type test to see the result .
(defun c:Test nil
  (vl-load-com)
  (princ)
Valued Contributor
mhlr
Message 8 of 14 (375 Views)
06-06-2012 06:55 AM in reply to: _Tharwat
Perfect. thanks so much for the help! I will try this on my lunch break & get back. I was just handed a deadline that has little time to complete from my boss!!
Valued Contributor
mhlr
Message 9 of 14 (353 Views)
06-07-2012 08:32 AM in reply to: mhlr
I'm sorry _Tharwat,
I loaded the code fine, AP says it loaded fine. I open multiple dwgs., minimize them, open one in the full editor & type "Test".
The Autcad screen flashes but nothing happens. I enter the command for Tile Vertical & the same dwgs. are still minimized. Does this work fine on your machine??
thanks again,
M.
_Tharwat
Message 10 of 14 (349 Views)
06-07-2012 09:11 AM in reply to: mhlr
mhlr wrote:
I'm sorry _Tharwat,
thanks again,
M.
That's really strange , it works as expected here .
You may have an old version of Autocad ?
You are not logged in.
Announcements
Need installation help?
Ask the Community
