aqdam1978
Message 1 of 16 (285 Views)
TextWidth before Text creation
285 Views, 15 Replies
03-02-2013 05:18 PM
I want to know is there any formula/calculation for the width of text object before creation/insertion?
at now I used apploximated width size via a simple code:
(Defun GetStrWidth (str H W) (fix (*(* H W) (strlen str))))
;;usage: (GetStrWidth "This is a Text." 2.5 0.8)
;;H: TextHeight; W: width factor.
I know that for the existed text in drawing I can use textbox command, but for the texts that has not been created,
what can I do?
Is there any formula/calculation depands on font name, text height and width factor?
Kent1Cooper
Message 2 of 16 (263 Views)
Re: TextWidth before Text creation
03-02-2013 08:59 PM in reply to: aqdam1978
Wow....  It's hard to imagine.  It would require not only the font, height, and width factor, but whatever is doing the calculation would need to know the widths of every possible character, to add them up for the characters used in the text string.  If you were only talking about .SHP/.SHX fonts, maybe something could be made to read the font files and figure all of that out, but as for other font types [TrueType, for the main possibility], I wouldn't have a clue whether it would be possible at all.
Kent Cooper
aqdam1978
Message 3 of 16 (259 Views)
03-02-2013 09:42 PM in reply to: Kent1Cooper
Hi Kent,
YES, you are right.
That simple code works fine for MonoSpaced fonts, but for other types of font, NO!
In programming languages (like Delphi), there is a "Form" and "Canvas" for project.
we can assign a font to Canvas and it's possible to get width of texts before insertion.
I thought maybe there is a solution in AutoLisp like as other visual form-based proframming languages!
Abbas
pbejse
Message 4 of 16 (249 Views)
03-03-2013 03:59 AM in reply to: aqdam1978
what can I do?
Curious what you want to achive here aqdam1978, perhaps there is another way thru textbox function. or is it a general question?
hmsilva
Message 5 of 16 (240 Views)
03-03-2013 06:24 AM in reply to: aqdam1978
Abbas,
perhaps creating a temporary object, something like
(defun test (str TS H W / txt txtobj ll ur llpt urpt brpt Width)
;; usage:(test "This is a Text." "Standard" 2.5 0.8)
;; TS TextStyle; H: TextHeight; W: width factor.
;; returns the text string with or nil
;; if text style doesn't exist...
  (if (tblsearch "style" TS)
    (progn
      (entmake (list
		 '(0 . "TEXT")
		 '(100 . "AcDbEntity")
		 '(8 . "0")
		 '(100 . "AcDbText")
		 '(10 0.0 0.0 0.0)
		 (cons 40 H)
		 '(1 . "This Is A Test")
		 '(50 . 0.0)
		 (cons 41 W)
		 '(51 . 0.0)
		 (cons 7 TS)
		 '(71 . 0)
		 '(72 . 0)
		 '(11 0.0 0.0 0.0)
		 '(210 0.0 0.0 1.0)
		 '(100 . "AcDbText")
		 '(73 . 0)
	       );; list
      );; entmake
      (setq txt (entlast))
      (setq txtobj (vlax-ename->vla-object txt))
      (vla-getboundingbox txtobj 'll 'ur)
      (setq llpt  (vlax-safearray->list ll)
	    urpt  (vlax-safearray->list ur)
	    brpt  (list (car urpt) (cadr llpt) (caddr llpt))
	    Width (distance llpt brpt)
      (entdel txt)
      Width
    );; progn
  );; if
);; test
Henrique
aqdam1978
Message 6 of 16 (235 Views)
03-03-2013 06:46 AM in reply to: pbejse
Hi Pbejse, assume that I want to make columns of text like this:
Column1 Column2 ... ColumnN
(setq Column1 (list "str1" "str2" "str3"..... "strN"))
(setq Column2 (list "str1" "str2" "str3"..... "strN"))
(setq ColumnN (list "str1" "str2" "str3"..... "strN"))
I put the fisrt column Texts in drawing via:
(setq X 0 Y 100)
(command "text" "s" "romans" "j" "ML" (list X (setq Y (- Y 5))) 0 (nth i Column1))
but for the second column:
(setq X (+ X dX) Y 100)
(command "text" "s" "romans" "j" "ML" (list X (setq Y (- Y 5))) 0 (nth i Column2))
So, I need dX value, dX is the widest text in Column1
in fact I need to calculate dX value for each column.
Abbas
pbejse
Message 7 of 16 (217 Views)
03-03-2013 07:35 AM in reply to: aqdam1978
I'll have a look-see tomorow Abbas :smileyhappy:
devitg
Message 8 of 16 (215 Views)
03-03-2013 07:41 AM in reply to: aqdam1978
What about using tables , check for the wide most text , and set column wide as need ?
aqdam1978
Message 9 of 16 (209 Views)
03-03-2013 08:03 AM in reply to: hmsilva
Hi Henrique,
Thanks for your code,
I also think there is no way except temporary creation!
I updated your code to:
(defun GetTextWidth (str TS H W / txt txtobj ll ur llpt urpt brpt Width fn)
;; usage:(GetTextWidth "This is a Text." "Standard" 2.5 0.8)
(if (not (tblsearch "style" TS))(progn (setq fn "romans.shx")
	(if (=(setq txt (getstring (strcat "Give the FONT NAME <" fn ">: "))) "") ()(setq fn txt))
	(command "-style" TS fn  2 1 0 "N" "N" "N"))
      (entmake (list
		 '(0 . "TEXT")
		 '(8 . "0")
		 '(100 . "AcDbText")
		 '(10 0.0 0.0 0.0)
		 (cons 40 H)
		 (cons 1 str)
		 '(50 . 0.0)
		 (cons 41 W)
		 '(51 . 0.0)
		 (cons 7 TS)
		 '(71 . 0)
		 '(72 . 0)
		 '(11 0.0 0.0 0.0)
		 '(210 0.0 0.0 1.0)
		 '(100 . "AcDbText")
		 '(73 . 0)
	       );; list
      );; entmake
      (entdel txt)
      Width
Abbas
hmsilva
Message 10 of 16 (204 Views)
03-03-2013 08:24 AM in reply to: aqdam1978
Abbas,
using
(setq lastent (entlast))
(setq ss (ssadd))
;;here your text stuff for Column1
;;(command "text" "s" "romans" "j" "ML" (list X (setq Y (- Y 5))) 0 (nth i Column1))
(while (setq lastent (entnext lastent))
(ssadd lastent ss)
You get all the new text in the selection set "ss". then, if you use the Kent Cooper's method in
"The smallest rectangle enclosing selected set of objects"
is easy to calculate "dX" value...
hope that helps
Henrique
You are not logged in.
Ask the Community
