aqdam1978
Message 1 of 6 (240 Views)
Text Trimming
240 Views, 5 Replies
02-02-2013 11:30 AM
I need a program to trim selected text(s) with a divisor.
suppose that the divisor character is: "/"
(selected text==>result:smileyhappy:
textL/textR ==> textR
xxx/yyy     ==>yyy
t12x/5678  ==>5678
I should use some commands like:
;;;;div="/":
(setq str "xxx/yyy")
(setq pos (vl-string-position (ascii "/") str))
(setq len (strlen str))
(setq RGT (substr str (+ pos 2) (-(- len pos)1))) ;;=text after "/"
but I need a LISP program that:
1-ask user to give a divisor char: (Divisor character: </>)
2-ask user to select text(s) but program should filter selected text(s) with divisor (*/* pattern)
(if (null #div#)(setq #div# "/"))
(if (and
(setq #div# if (= (setq tmp (getstring (strcat "\nDivisor character: <" #div# "> ") ) ) "" ) #div# tmp ) )
(setq ss (ssget "_:L" (list '(0 . "*TEXT") (cons 1 (strcat "*" #div# "*")))))
Can anybody help me?
hmsilva
Message 2 of 6 (229 Views)
Re: Text Trimming
02-02-2013 01:02 PM in reply to: aqdam1978
aqdam1978,
perhaps something like
  (if (or (not #div#) (/= (type #div#) 'STR)) (setq #div# "/"))
  (setq tmp (getstring (strcat "\nDivisor character: <" #div# "> ")))
  (if (= tmp "") (setq tmp #div#) (setq #div# tmp))
  (setq str (cdr (assoc 1 (entget (ssname ss 0)))))
  (setq pos (vl-string-position (ascii #div#) str))
Henrique
aqdam1978
Message 3 of 6 (221 Views)
Re: Text Trimming
02-02-2013 04:07 PM in reply to: hmsilva
Hi Hmsilva,
Thank you for your help.
I change the LISP program to:
(defun C:p074()
(vl-load-com)
  (if (and #div# SS)
      (repeat (setq itm (sslength ss))
	(setq obj (vlax-ename->vla-object (ssname ss (setq itm (1- itm)))))
	(setq str (vla-get-textstring obj))
	(vla-put-textstring obj (substr str (+ pos 2) (-(- len pos)1)))
      );; repeat
  );if
  (princ)
 I would like to know is there any changes that I should do but I forgotted?
some programming tips that made our LISP program as a optimum code....
Thank you for your consideration
Kent1Cooper
Message 4 of 6 (213 Views)
Re: Text Trimming
02-02-2013 07:50 PM in reply to: aqdam1978
Two things come to mind:
1)  You could probably eliminate the (/= (type #div#) 'STR) test, and the (or) that includes it.  I don't see any way, if it exists, that it could be any other type [unless you're also using the same variable name in some other routine, in which case you should change the name of one of them].  Try just:
(if (not #div#) (setq #div# "/"))
And you could shorten it further by doing it this way:
(or #div# (setq #div# "/"))
which would work, though I prefer the first one, which seems more "descriptive" of what's going on.
2)  The (substr) function's 'length' argument is optional.  If you omit it, it will just go from the 'start' position to the end of the string, however long that is, which seems like what you want to do.  Try just:
(vla-put-textstring obj (substr str (+ pos 2)))
Kent Cooper
hmsilva
Message 5 of 6 (198 Views)
Re: Text Trimming
02-03-2013 06:49 AM in reply to: aqdam1978
You're welcome, aqdam1978
Henrique
hmsilva
Message 6 of 6 (191 Views)
Re: Text Trimming
02-03-2013 07:58 AM in reply to: aqdam1978
aqdam1978 wrote
... I would like to know is there any changes that I should do but I forgotted? some programming tips that made our LISP program as a optimum code....
sorry,read too quickly, and not read to the end, regarding code changes and tips, after Kent Cooper's "Expert Elite* advices, is difficult to provide better advices, but I saw a few things that can improve the code performance, so, is good practice to declare the variables that we use as local variables, when they are local, and notice that I have not declared local the variable #div#, to be available for the next time you run the code, in the same dwg and in the same AutoCad session, the other variables have been declared local,so they are not occupying memory, and will not remain set values to these variables, and will not enterin in conflict with other code that uses the same variables.
(defun C:p074 (/ tmp ss itm obj str pos)
(vl-load-com)
  (if (and #div# SS)
      );; repeat
  );if
  (princ)
hope that helps
Henrique
You are not logged in.
Ask the Community
