Table - insertion point
5 REPLIES 5
ProfWolfMan
1235 Views, 5 Replies
I am just trying to create a table.
Please see below code.
(defun fn-drawtable()
  (vl-load-com)
  (setq ms(vla-get-Modelspace(vla-get-ActiveDocument(vlax-get-acad-object))))
  (setq mytable(vla-addtable ms (vlax-3d-point '(0 0 0)) 3 8 5 10)) )
It creates table with insertion point at upper left corner.
table help document also tells like that.
Now i want to change it's insertion point as upper right corner.
I tried with vla-put-direction. But i can not.
vla-put-FlowDirection changes it cells direction up and down only.
Please help me to change it's insertion point.
Thanks & Regards,
G
5 REPLIES 5
phanaem
in reply to: ProfWolfMan
You can extract width of tabe (setq table_width (vla-get-width mytable)) and then move it to the left
(vla-Move mytable (vlax-3d-point '(0 0 0)) (vlax-3d-point (list (- table_width) 0 0)))
ProfWolfMan
Yes. I already achieve by that way only.
But i want to know if there is any other properties or methods in table entity without using move or mirror kind of commands.
Thanks for your valuable time and comment.
Thanks & Regards,
G
pbejse
you can try changing the insertionpoint, but then again its the same as moving  the table
(vla-put-insertionpoint
      mytable
      (vlax-safearray-fill
        (vlax-make-safearray vlax-vbDouble '(0 . 2))
        (list (- 0 (vla-get-width mytable)) 0 0)))
Tell us again why you need the table to be on the upper right corner?
ProfWolfMan
in reply to: pbejse
Ohhhhhhhhhhhh!
my mental block does this.thanks to clear that.
i can find upper left corner of table and now everything is ok.
No need to change insertion point of table.
Thanks & Regards,
G
eurikadance
in reply to: pbejse
This is a great start for me, as I'm just starting with Visuallisp.  However, is there way to take this vla-move further by extracting the insertionpoint property of the table (vla-get mytable 'insertionpoint) and incrementally move the table by adding to either the x or y coordinate of the insertion point?
”Boost
