Why not just enter "import export lisp utility" in Internet Explorer.
Mode: lisp; Syntax: ansi-common-lisp; Base: 10; Package: de.setf. ...
... de.setf.utility.package:package-version) :common-lisp-user)) (eval ...
:use :import-only :import-from :intern-only :intern :export-only :export ...
home.arcor.de/james_anderson/setf/library/ de/setf/utility/package.lisp -
30k - Cached - Similar pages
Info Node: (dir)Top
... R Data R Data Import/Export. ... for 2-D vector graphics Appendices More
info on the plotting
utilities User Interface ... CL Partial Common Lisp support for Emacs Lisp
www2.cs.washington.edu/uns/cgi/info2www.pl?(DIR)Top - 21k - Cached - Similar
pages
modutils - Module utilities
... in a modular way: traditional Lisp's feature based ... you don't ; need
to import them
explicitly. ... (export extfn1 extfn2) ; Declare external symbols, ; using
STk's ...
www.shiro.dreamhost.com/scheme/vault/modutils.html - 10k - Cached - Similar
pages
Lisp File L to O
... MBLOK.ZIP, 1K, utility to easy create and edit blocks in ... NTEXT.ZIP,
3k, text-will
import export text to/from autocad ... NTHEDIT.ZIP, 2k, save LISP variables
in a dwg. ...
www.cadresource.com/library/lisplo.html - 51k - Cached - Similar pages
Free Stuff
... 2000. applist.arx. ARX Utility (APPLIST command) lists all loaded LISP
files. 2000. ... R14.
ascpoint.lsp. Import/Export Coordinate Data from ASCII/CDF files. R10+. ...
mysite.verizon.net/~vze2vjds/free.htm - 35k - Cached - Similar pages
"akdrafter" wrote in message
news:11377912.1077660185056.JavaMail.jive@jiveforum2.autodesk.com...
> Hello All,
> Does anyone know of any routines, apps that are free for importing txt
files into a table like format?
> Thanks in advance.
> "Catch" Ya Later,
> AKDRAFTER
