• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Member
    TAB angle lock
    246 Views, 5 Replies
    06-15-2012 02:10 PM
    Hi guys I want to create a shortcut key (like TAB) for example and whenever I start a polyline or move or whatever, I can hit TAB which will grab the angle my cursor is at, and then use the angle lock to lock the cmd into that direction. (This is essentially what can be done in rhino if you are familiar with this).
    The manual way in autocad is typing it ("<45") but I just want to calculate angle from the start point to cursor point. and then once hitting tab or a key or a new command, it will lock with that angle. How can I go about programming this, I have never programmed in autocad but am eager in learning how this might be possible. Thanks so much!
    Please use plain text.
    *Pro
    scot-65
    Re: TAB angle lock
    06-15-2012 03:38 PM in reply to: cjm771
    Look at the available transparent commands - the ones with the 'hyphens in front
    as well as assigning the "F-Keys".
    If not mistaken, you will need to set up UCS names, but I do not know if UCS is a
    transparent command.
    Would you consider reversing the order?
    Meaning rotate the UCS first, then start the command?
    I know that can be done.
    Attached image is a screen capture showing how to assign a F-key.
    You might need to define a command name first (not sure) or write
    the macro: ucs;[your ucs name];...
    Command CUI will get you there.
    Drag and drop the command from the lower-left pane into the tree above.
    Highlight the line you just created in the tree and edit in the lower-right pane.
    Re: TAB angle lock
    06-15-2012 11:03 PM in reply to: cjm771
    What about Polar Tracking or F10
    At Polar Angle Settings
    -Increment angle 45
    HTH
    Kent1Cooper
    Re: TAB angle lock
    06-16-2012 04:17 AM in reply to: cjm771
    This does it if you type (sca) [including the parentheses] when a prompt is asking for a next point, such as in Line or Move or Copy.  I leave it to you to assign (sca) to a Function key or Alt-whatever or other key combination.
    (defun sca (); = Snap to Crosshair-location Angle
      (setvar 'snapang
        (angle
          (getvar 'lastpoint)
          (cadr (grread T))
      (setvar 'orthomode 1)
      (princ)
    Kent Cooper
    Member
    Re: TAB angle lock
    06-17-2012 04:12 PM in reply to: cjm771
    Thanks kent!
    Works great!! Only two questions
    1) is it possible that upon completion of the next click (if it is a polyline or the end of a move command or whatever..) can it return to the normal non ortho mode? It seems it gets stuck in ortho at that angle forever.that would be awesome!
    2) It is posisble that once in this sca mode...that even if i osnap to a point...that it will still conform to the angle and esentially project (like an strack situation) to keep with that angle?
    Also  what is a good documentation to learn this AutoLISP, I very much would like to learn! Thanks, again!
    Valued Mentor
    Re: TAB angle lock
    06-18-2012 02:54 AM in reply to: cjm771
    adapting Kent's suggestion you could assign the macro
    ^P(strcat "<" (angtos (angle (getvar 'lastpoint) (cadr (grread T))))) ^P
    to a function key or other shortcut key combination,
    This will handle your 1st request.
    For your 2nd request, you could try turning on osnap tracking
    with the F11 key before or after using the above macro.
    Ian
