• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Active Contributor
    Switching between 'Use Icons' option
    125 Views, 4 Replies
    06-14-2011 03:32 AM
    Anybody know the Setenv, Setvar, Registry switch to change the bottom option bar (Snap, Grid, Ortho, Polar etc.) from icons to text please?
    I know yu can right click and change it there, but I would like to do it when setting up new Autocad upgrades.
    Please use plain text.
    Distinguished Mentor
    Moshe-A
    Re: Switching between 'Use Icons' option
    06-14-2011 11:10 AM in reply to: eddyrichardson
    Eddy,
    look inside the following registry key
    HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:xxx\Profiles\StatusBar\Application
    Cheers
    Moshe
    Active Contributor
    06-15-2011 02:40 AM in reply to: eddyrichardson
    I found the registry value here:
    Profiles / <myprofile> / General / "AppStatusBarUseIcons" =dword:00000000 (0) for off and 00000001 (1) for on.
    Problem is that:
    (vl-registry-write
    (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\<my profile>\\General\\")
    "AppStatusBarUseIcons" 0)
    Does not work - any suggestions?
    Moshe-A
    06-15-2011 09:47 AM in reply to: eddyrichardson
    Sorry i do not have "Profiles / <myprofile> / General / AppStatusBarUseIcons" key
    what autocad version are you using?
    Active Contributor
    06-20-2011 01:31 AM in reply to: eddyrichardson
    We are on Autocad Architecture 2012 I've just checked and it's the same for 2011... search your registry for:
    "AppStatusBarUseicons"
