Hi everybody,
Here is what i want to be helped, i have many attribute blocks with various names and each block has two attributes, one is a string and another is a number . Then i want to sum all tag value number that have the same String.
For example :
Block 1 Block 2 Block3 Block4
Block name : Lamp1 Lamp2 Lamp3 Lamp4
Attribute 1 : L1 L2 L1 L2
Attribure 2 : 50 100 20 70
Then the result i expected is a report as below:
String Block name Total
L1 Lamp1, Lamp3 70
L2 Lamp2, Lamp4 170
Thank in advance for your help !
Solved by braudpat. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
I think that using ATTOUT (Express Tools Command), you will generate a CSV file with :
Handle , Block Name , Attribute1 , Attribute2 , etc
Then you load the CSV into Excel, and you can do the job (with Excel) ...
Patrice BRAUD
Hi braudpat,
That's great, i used ATTOUT and export to a txt file, I pasted all of data to excel and then use Pivot Table tool . It took me just 3 minutes to get what i need .
Thank you very much !
