The_Caddie
Message 1 of 7 (310 Views)
Strange error message in LISP
310 Views, 6 Replies
05-01-2012 05:08 AM
I am trying to create a line between two defined points but get the following error
; error: An error has occurred inside the *error* function AutoCAD variable  setting rejected: "DYNMODE" nil
I have googeld it but can’t find anything on it. Just as some background information I didn’t use DYNAMODE or any error function, which has me a bit baffled then
Anyways here's the troubled code snippet.
(command "line" MYPOINT (strcat MYDIST ,0 ,0))
Also tried
(command "line" MYPOINT MYPOINT2)
Doesn’t do anything either…
Kent1Cooper
Message 2 of 7 (306 Views)
Re: Strange error message in LISP
05-01-2012 05:50 AM in reply to: The_Caddie
... here's the troubled code snippet.
Also tried
I couldn't say about DYNMODE without seeing the whole routine, but as for the (command) functions:
The first one, assuming MYDIST is a distance [real number] in the X direction othat you want to go from MYPOINT, should be either
(command "line" MYPOINT (strcat "@" (rtos MYDIST) ",0,0") "")
or
(command "line" MYPOINT (polar MYPOINT 0 MYDIST) "")
or there are a few other ways it could be done.
The second one also needs a "" [Enter] at the end to complete the Line command.
Kent Cooper
The_Caddie
Message 3 of 7 (304 Views)
05-01-2012 05:57 AM in reply to: Kent1Cooper
The cursor places the line but keeps on holding on to its endpoint and wont place that. Though the error has now changed to ; error bad argument type: numberp: nil
EDIT:
a better way to tackle this is perhaps to show me how I can place a line using two variables set to coordinate values found in model space.
After all the problem is how do I use variables to place a line.
(sorry my fault, complicated explanations)
Kent1Cooper
Message 4 of 7 (300 Views)
05-01-2012 06:04 AM in reply to: The_Caddie
The_Caddie wrote:
The cursor places the line but keeps on holding on to its endpoint and wont place that. though the error has now changed to ; error bad argument type: numberp: nil
That means some AutoLISP function that is expecting a number is being given nil instead.  The most likely reason for that is that the MYDIST variable does not have a value set into it, which is causing trouble for (rtos) and (polar).
Kent Cooper
The_Caddie
Message 5 of 7 (296 Views)
05-01-2012 06:09 AM in reply to: Kent1Cooper
yeah oops mabey if i spelled the two instances of the MYDIST and MYDIST1 variables equally the problem would go away (red faced:womanembarrassed:)
Kent1Cooper
Message 6 of 7 (291 Views)
05-01-2012 06:23 AM in reply to: The_Caddie
The_Caddie wrote:
... how I can place a line using two variables set to coordinate values ....
It appears from further messages that you've got it working, but in answer to the above:  The last line of code in your original post, with "" [Enter] added at the end to complete the Line command, would be the usual way.
Kent Cooper
The_Caddie
Message 7 of 7 (288 Views)
05-01-2012 06:53 AM in reply to: Kent1Cooper
Yes that worked with the enter...
You are not logged in.
Ask the Community
