• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    The_Caddie
    Accepted Solution
    Strange error message in LISP
    174 Views, 6 Replies
    05-01-2012 05:08 AM
    I am trying to create a line between two defined points but get the following error
    ; error: An error has occurred inside the *error* function AutoCAD variable  setting rejected: "DYNMODE" nil
    I have googeld it but can’t find anything on it. Just as some background information I didn’t use DYNAMODE or any error function, which has me a bit baffled then
    Anyways here's the troubled code snippet.
    (command "line" MYPOINT (strcat MYDIST ,0 ,0))
    Also tried
    (command "line" MYPOINT MYPOINT2)
    Doesn’t do anything either…
    Please use plain text.
    *Expert Elite*
    Kent1Cooper
    Re: Strange error message in LISP
    05-01-2012 05:50 AM in reply to: The_Caddie
    ... here's the troubled code snippet.
    Also tried
    I couldn't say about DYNMODE without seeing the whole routine, but as for the (command) functions:
    The first one, assuming MYDIST is a distance [real number] in the X direction othat you want to go from MYPOINT, should be either
    (command "line" MYPOINT (strcat "@" (rtos MYDIST) ",0,0") "")
    or
    (command "line" MYPOINT (polar MYPOINT 0 MYDIST) "")
    or there are a few other ways it could be done.
    The second one also needs a "" [Enter] at the end to complete the Line command.
    Kent Cooper
    The_Caddie
    05-01-2012 05:57 AM in reply to: Kent1Cooper
    The cursor places the line but keeps on holding on to its endpoint and wont place that. Though the error has now changed to ; error bad argument type: numberp: nil
    EDIT:
    a better way to tackle this is perhaps to show me how I can place a line using two variables set to coordinate values found in model space.
    After all the problem is how do I use variables to place a line.
    (sorry my fault, complicated explanations)
    *Expert Elite*
    Kent1Cooper
    05-01-2012 06:04 AM in reply to: The_Caddie
    The_Caddie wrote:
    The cursor places the line but keeps on holding on to its endpoint and wont place that. though the error has now changed to ; error bad argument type: numberp: nil
    That means some AutoLISP function that is expecting a number is being given nil instead.  The most likely reason for that is that the MYDIST variable does not have a value set into it, which is causing trouble for (rtos) and (polar).
    Kent Cooper
    The_Caddie
    05-01-2012 06:09 AM in reply to: Kent1Cooper
    yeah oops mabey if i spelled the two instances of the MYDIST and MYDIST1 variables equally the problem would go away (red faced:womanembarrassed:)
    *Expert Elite*
    Kent1Cooper
    05-01-2012 06:23 AM in reply to: The_Caddie
    The_Caddie wrote:
    ... how I can place a line using two variables set to coordinate values ....
    It appears from further messages that you've got it working, but in answer to the above:  The last line of code in your original post, with "" [Enter] added at the end to complete the Line command, would be the usual way.
    Kent Cooper
    The_Caddie
    05-01-2012 06:53 AM in reply to: Kent1Cooper
    Yes that worked with the enter...
