I am have trouble trying to figure a couple of things in the following code. Any advice??
First - in the IF statement if "SD" is >= ask "Specify LAST strata number". How do I add nil?
Second - After I "Specify the LAST strata number", How do I stop the loop?
(defun C:22 () (setvar 'osmode 0) (or $S (setq $S 10)) (setq S (getdist (strcat "\nSpecify scale [Inches equal a Foot] <"(rtos $S 2 2)">: "))) (if (= S nil) (setq S $S)) (setq $S S) (or $BD (setq $BD 7)) (setq BD (getdist (strcat "\nSpecify boring depth in feet <"(rtos $BD 2 2)">: "))) (if (= BD nil) (setq BD $BD)) (setq $BD BD) (setq P1 (getpoint "\nSpecify starting point: ") P2 (list (+ 1.5 (car P1)) (cadr P1)) P3 (list (car P2) (- (cadr P2)(* BD S))) P4 (list (- (car P3) 3) (cadr P3)) P5 (list (car P4) (cadr P2)) ) (command "pline" P2 P3 P4 P5 "C") (while (setq SD (getdist "\nSpecify strata depth: ") SD1 (list (car P5) (- (cadr P5) (* SD S))) SD2 (list (+ 3 (car SD1)) (cadr SD1)) ) (if (>= SD BD) (progn (setq SN (getint "\nSpecify LAST strata number: ") SN1 (list (car P2) (- (cadr P2) (/ (distance P2 P3) 2))) ) (command "text" "m" SN1 1.0 "0" SN) ) ) (setq SN (getint "\nSpecify strata number: ") SN1 (list (car P2) (- (cadr P2) (/ (distance P2 SD2) 2))) ) (command "line" SD1 SD2 "") (command "text" "m" SN1 1.0 "0" SN) (setq P2 SD2) ) (princ) )
1. 'add nil' does not compute, as you discovered. One way around:
test the variable for a nil content, and if nit set it to the number 0, ie,
(if (not SD) (seta SD 0)) ; handle a nil entry; and inside the setq:
SD (if SD SD 0) .... etc
2. 'stop the loop' of a while could be, in your case, either:
A. Add an user input in the while argument of ' (While (Setq ..
like : (while (and (/= "Y" (strcase (getstring "\n Exit, Y or N")))
SD (if SD SD 0)
) ; and
