I am attaching the .lsp file and at the bottom of the lisp routine is the .dcl file.
What I need: I need for my selections to show up in the edit boxes...i.e.-when I select a block I need the name to show up in the edit box.
I also need for the dialog box to let me exit to insert a new block, when you see the lsp file you'll know where i am going with that...The file_dia.dcl works fine so far...that's why it is not attached...if you need this file I can send it to you....
Thank for any help....
