Visual LISP, AutoLISP and General Customization
Start App
17 REPLIES 17
Message 1 of 18
315 Views, 17 Replies
Start App
I know this works ..... (startapp "notepad" "C:/Extraction/Extract.mns")
with this in acad.pgp ..... NOTEPAD, START NOTEPAD, 1,*File to edit:,
but this dosen't ...... (startapp "excel" "C:/Extraction/Extraction.xls")
with this in acad.pgp ...... EXCEL, START EXCEL, 1,*File to edit:,
Can anyone point me in the right direction?
17 REPLIES 17
Message 2 of 18
Chip...
You'll need to provide the complete path to excel...
Tom
"Chip Harper" wrote in message
news:852F8BD2778A6B589DDB6FAE38086AB6@in.WebX.SaUCah8kaAW...
Message 3 of 18
Ok, makes sense .... I changed the acad.pgp to read ...
EXCEL, START "C:/Program Files/Microsoft Office/Office/Excel.exe",
1,*File to edit:,
Typing EXCEL at the command prompt works .. it prompts for the file to edit,
I give it the path and it opens correctly .... Half way there ..
This .... (startapp "excel" "C:/Extraction/Extraction.xls") returns nil
where as
(startapp "notepad" "C:/Extraction/Extract.mns") opens correctly ... what I
am I missing?
"Tom B" wrote in message
news:965BAC46F032E10763BAC63A0858F510@in.WebX.SaUCah8kaAW...
> Chip...
> Tom
Message 4 of 18
(startapp "C:/Program Files/Microsoft Office/Office/Excel.exe"
news:C66262363F9AC2759E9E0E0F3D7FCD30@in.WebX.SaUCah8kaAW...
1,*File to edit:,
where as
am I missing?
> Chip...
> Tom
Message 5 of 18
Nope, it will open excel but with the warning that 'extraction.xls' not
found, check path, spelling yada yada.
Leaving the Excel command in the acad.pgp file I wrote a quick script ...
Excel
This opens it to the correct file ... this is driving me nuts. Any idea why
its not working with (startapp)?
And Thanks a Million for your help Tom.
news:70462061BCC27E35B98C22D842A52E72@in.WebX.SaUCah8kaAW...
Message 6 of 18
OK... I fixed it. Sometimes I am so stupid.... AutoLISP doesn'r see \ as \
so you use / or \\. Windows doesn't recognise / in directory names... so
you need to set your string up like this:
"C:\\Extraction\\Extraction.xls")
so windows sees \ because AutoLISP converts \\ to \!!!!
Go ahead... try it!
Tom
news:8737277E3C7FE05EA60DCF5A4EB1980C@in.WebX.SaUCah8kaAW...
Excel
Message 7 of 18
Yikes, I hate to say it, but no ... I even tried coping and pasting just in
case I had a typo ...
this is what I get at the command line ...
Command: (startapp "C:/Program Files/Microsoft Office/Office/Excel.exe" "C:
news:E8E13584F49ED8085FF9539FE8DAC22A@in.WebX.SaUCah8kaAW...
> Go ahead... try it!
> Tom
Message 8 of 18
That all should be on one line... watch for wrap...
news:EEAE3EEC71BC4928E1B1FDE60552292B@in.WebX.SaUCah8kaAW...
> Go ahead... try it!
> Tom
Message 9 of 18
I put it in as 1 line with a space between the quote marks { .exe" "C:\\ }
and without the space and I get this at the command line ...
news:28DA004508DB303BA8EE194A041DBBB9@in.WebX.SaUCah8kaAW...
Message 10 of 18
Best I can figure out .. it sees the first \ after the c: as a pause and is
waiting for a entry at the comand line. It it makes any difference this is
being used on a partial menu. Here is the entire line ...
ID_EXCEL [<-Open Excel Worksheet](startapp "C:/Program Files/Microsoft
Office/Office/Excel.exe" "C:\\Extraction\\Extraction.xls")
Message 11 of 18
Chip... you are killing me here... Here is the result on my A2k command
line:
(_> "C:\\Extraction\\Extraction.xls")
-31641
And here is the result on my A14:
1> "C:\\Extraction\\Extraction.xls")
35151
and in IntelliCAD
38157
You can also leave out the space in between Excel.exe" "C:\Extract... like
below:
Office/Office/Excel.exe""C:\\Extraction\\Extraction.xls")
Tom
news:8081E7B5DE20F5CE7C96D1360C4F1852@in.WebX.SaUCah8kaAW...
Message 12 of 18
It works directly at the command line but not as part of a partial menu, as
I was trying to use it. Wacky stuff. Thanks Tom.
news:D277C20EEE73E909DF59144901B6B2D8@in.WebX.SaUCah8kaAW...
> line:
> -31641
> 35151
> and in IntelliCAD
> 38157
> below:
> Tom
"C:
Message 13 of 18
I test Tom line and it works fine here too
(startapp (findfile
) ;_ eoffindfile
(if (setq myxls (findfile "C:\\Extraction\\Extraction.xls"))
myxls
) ;_ eofif
) ;_ eofstartapp
(startapp
(if (setq xls (findfile
) ;_ eoffindfile
) ;_ eofsetq
xls
) ;_ eofif
(if (setq book (findfile "C:\\Extraction\\Extraction.xls"))
book
) ;_ eofif
) ;_ eofstartapp
Good Luck,
LE
Tom B wrote in message ...
>line:
>-31641
>35151
>and in IntelliCAD
>38157
>below:
>Tom
Message 14 of 18
+Office/Office/Excel.exe" "C:\\Extraction\\Extraction.xls")
news:51C47530810AB235F1A8C08157C8B6DE@in.WebX.SaUCah8kaAW...
Message 15 of 18
Chip,
The reason that your code do not fit in one line you need to add "+", but
when the mns is created line continuation are not preserved
your choice can be something like this ...
(defun openExcel ()
(startapp
) ;_ eoffindfile
) ;_ eofsetq
xls
) ;_ eofif
; book
; ) ;_ eofif
) ;_ eofstartapp
(princ)
) ;_ eofdefun
[&Open Excel Worksheet]^C^C(openExcel)
Good Luck,
Chip Harper wrote in message
<51C47530810AB235F1A8C08157C8B6DE@in.WebX.SaUCah8kaAW>...
Files/Microsoft
Message 16 of 18
Chip...
Did you see the plus sign in my last post?
That should square you away!
Tom
Message 17 of 18
Yes I did Tom, just haven't had a chance to post back. Can you believe some
people actually expect you to do work on a friday? Everything is running
smoothly, Thanks for all your assistance Tom. Greatly appreciated.
news:E79DDB3A21092D7093E59B956D7D3EEF@in.WebX.SaUCah8kaAW...
> Chip...
Files/Microsoft
> Tom
Message 18 of 18
Chip...
You are welcome. As far as working on friday goes.... I had 60 hours when
I went home last nite... and they expected me to work 8 today... not
likely!
Tom
news:2E4896EDDA1B6D28BA2601B44C444665@in.WebX.SaUCah8kaAW...
some
> > Chip...
> Files/Microsoft
> > Tom
”Boost
