Distinguished Contributor
Redraiderr2009
Message 11 of 15 (154 Views)
Re: Sorting a List
01-18-2013 07:33 AM in reply to: Kent1Cooper
  (setq BlockDataBase
        (("00_CATEGORY_NUM" "CCC") ("BlockName" "Tree-03-08-CC8"))
	(("00_CATEGORY_NUM" "CCC") ("BlockName" "Tree-03-10-CC10"))
	(("00_CATEGORY_NUM" "AAA") ("BlockName" "Tree-02-08-QS3"))
	(("00_CATEGORY_NUM" "AAA") ("BlockName" "Tree-02-20-QS10"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-36-07-LPC"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-36-01-LP"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-36-03-L"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-30-07-KL"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-30-12-UP"))
	(("00_CATEGORY_NUM" "SSS") ("BlockName" "Shrub-30-08-TY"))
	(("00_CATEGORY_NUM" "HHH") ("BlockName" "Hatch-16-ATR@10"))
	(("00_CATEGORY_NUM" "HHH") ("BlockName" "Hatch-01-ZZ@4"))
	(("00_CATEGORY_NUM" "HHH") ("BlockName" "Hatch-05-AA@12"))
); list ); setq ; sort block data record alphabetically to put the category first ;; (setq BlockDataBase (vl-sort BlockDataBase '(lambda (A B) (cond ((< (cadar A) (cadar B))) ((= (cadar A) (cadar B)) (< (cadadr A) (cadadr B)) (< (substr (cadadr A) (+ (vl-string-position (ascii "-") (cadadr A) 0 T)2)) (substr (cadadr B) (+ (vl-string-position (ascii "-") (cadadr B) 0 T)2)) ) ) );_end cond );_end lambda );_end vl-sort );end setq
In the code above I am trying to sort this list and I need a way to get them to sort according to size. Please see the attached image to see the results of this sort. I basicially need "Tree-02-20-QS10" to come before "Tree-02-08-QS3". The sort will put the 1 (in ten) ahead of the 3 even though the 10 is a higher number than 3. I am thinking that if one has more charcters than the other then it should sort the list by character length. I do not know enough about list manipulation to accomplish this.  I am wondering if anyone has any insight into this or if someone has run into this and had a solution.
Thanks in advance.
Russell
Redraiderr2009
Message 12 of 15 (137 Views)
Re: Sorting a List
01-18-2013 09:02 AM in reply to: Redraiderr2009
Sort of works but I am missing something.
(setq BlockDataBase
(("00_CATEGORY_NUM" "CCC") ("BlockName" "Tree-03-06-CC12"))
(("00_CATEGORY_NUM" "AAA") ("BlockName" "Tree-02-22-QS13"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-36-07-LPC"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-36-01-LP"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-36-03-L"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-30-07-KL"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-30-12-UP"))
(("00_CATEGORY_NUM" "GGG") ("BlockName" "Shrub-30-08-TY"))
); list
); setq
(setq test
'(lambda (A B)
(cond
(< (nth 1 (nth 0 A)) (nth 1 (nth 0 B)))
(= (nth 1 (nth 0 A)) (nth 1 (nth 0 B)))
(< (nth 1 (nth 1 A)) (nth 1 (nth 1 B)))
(substr (nth 1 (nth 1 A)) (+ (vl-string-position (ascii "-") (nth 1 (nth 1 A)) 0 T) 2))
(substr (nth 1 (nth 1 B)) (+ (vl-string-position (ascii "-") (nth 1 (nth 1 B)) 0 T) 2))
(strlen (nth 1 (nth 1 A)))
(strlen (nth 1 (nth 1 B)))
Kent1Cooper
Message 13 of 15 (133 Views)
Re: Sorting a List
01-18-2013 09:13 AM in reply to: Redraiderr2009
Redraiderr2009 wrote:
... I need a way to get them to sort according to size. Please see the attached image to see the results of this sort. I basicially need "Tree-02-20-QS10" to come before "Tree-02-08-QS3". The sort will put the 1 (in ten) ahead of the 3 even though the 10 is a higher number than 3. I am thinking that if one has more charcters than the other then it should sort the list by character length. ....
Are the components following the last hyphen always two letters followed by numbers?  If so, it shouldn't be very hard to adjust the starting position of the (substr) to bypass those and just look at the numerical characters following.  Even if it may not always be two, it's possible to have any characters you list trimmed off, so you could designate the whole alphabet to eliminate one, or three, or however many, alphabetic characters.  But it would involve converting the remaining numerical characters into integers and comparing those values numerically, not as text strings alphabetically.
Kent Cooper
Redraiderr2009
Message 14 of 15 (125 Views)
Re: Sorting a List
01-18-2013 10:44 AM in reply to: Kent1Cooper
I can say there are a minimum of two characters and then a size which can be 1 or 2 digit numbers. (Now watch .... someone will invent a reason to have a three digit number :smileyfrustrated :smileyhappy:. I would say that a three digiit number would be abnormal.
Some examples of the data that I deal with.
***Tree blocks usually have two to three characters and have one to two digits
Tree-02-20-QV3
Tree-02-20-QV6
Tree-02-20-QV10
Tree-02-20-QV12
Tree-04-08-LIN8
Tree-04-10-LIN10
Tree-04-12-LIN12
*** Shrub blocks usually have no numbers but there are times for it
Shrub-36-02-IVN
Shrub-30-04-TA5
Shrub-36-08-TA10
**Hatch blocks are usually inserted with the hatch to provide the information needed.
Hatch-01-LM@12
Hatch-04-AA@8
Hatch-02-LMM@10
Hatch-11-ROPP@24
Active Contributor
AlessiMarc'Antonio
Message 15 of 15 (106 Views)
Re: Sorting a List
01-19-2013 06:48 AM in reply to: Redraiderr2009
perhaps there is not this problem in your case but if you have to sort other kinds of lists
please note that vl-sort can delete elements that it sees as equal (maybe only if atoms):
(vl-sort
 '(3 2 1 3 1 2 2 2)
=> (1 2 3)
;  original by tony tanzillo (please note
;  the name change, i.e. "_" instead of "-")
(defun VL_Sort ( lst func )
      (mapcar
        '(lambda (x) (nth x lst))
         (vl-sort-i lst func)
(VL_Sort
 '(3 2 1 3 1 2 2 2)
=> (1 1 2 2 2 2 3 3)
Marc'Antonio Alessi
http://alessi.xoom.it//alessi/Programmi.htm
(vl-string-translate "1234567890" "ie@mst.lan" "499825513610716")
2D Parametric for 2000-2013
You are not logged in.
Ask the Community
