A while back ago with the help of others here I have a lisp that will take a profile and label the elevation of the existing grade and the invert of the pipe. However now I need to modify to all the slopes and every 50M intervals. The Idea I have is to take the elevations and use them to calculate the slope and add the label. I have attacked a cad file with some additional information and the code that adds the elevation. My goal is for the code to select the text, calculate the slope and insert a label with the slope identified. If someone can help me get the main part of the code that would be awesome. Thanks for all help.
Hi, sorry for the belating,
I need more info about your problem
Please read my message in PM
Oleg
The anwser is some of them are blocks and some are not. That is why in the PPL code it ask the user if it is a block or not. Thanks
Please apologize me , I put my finger in movement before my brain.
I will check now .
By the way , where are you?.
Rphillips , find attached what I can did .It work on exploded charts , you will need to explode it before.
If it fullfill your need , I will send the routine to use.
