Visual LISP, AutoLISP and General Customization
Slope lable lisp
7 REPLIES 7
Message 1 of 8
1332 Views, 7 Replies
Slope lable lisp
A while back ago with the help of others here I have a lisp that will take a profile and label the elevation of the existing grade and the invert of the pipe. However now I need to modify to all the slopes and every 50M intervals. The Idea I have is to take the elevations and use them to calculate the slope and add the label. I have attacked a cad file with some additional information and the code that adds the elevation. My goal is for the code to select the text, calculate the slope and insert a label with the slope identified. If someone can help me get the main part of the code that would be awesome. Thanks for all help.
7 REPLIES 7
Message 2 of 8
Hallex
Hi, sorry for the belating,
I need more info about your problem
Please read my message in PM
Oleg
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 8
devitg
All your drawing are Blocks, do you pretend to mantain it as block , or  can it be exploded?
Message 4 of 8
The anwser is some of them are blocks and some are not. That is why in the PPL code it ask the user if it is a block or not. Thanks
Message 5 of 8
devitg
Please apologize me , I put my finger in movement before my brain.
I will check now .
By the way , where are you?.
Message 6 of 8
devitg
Rphillips , find attached what I can did .It work on exploded charts , you will  need to explode it before.
If it fullfill your need , I will send the routine to use.
Message 7 of 8
in reply to: devitg
Thanks for your help I will download this and let you know.
Message 8 of 8
in reply to: devitg
Looks good to me, i am sure i will make some monor tweeks. Please send
Thanks again.
”Boost
