Hello I create the LISP script (attached) to find the shortest distance between two skew lines.
Finnally, I want to draw a segment which represents this shortest distance. It should be a line between apperen intersections of: PR1 and PR2 lines and PR2 and PR1 lines (on the screen they will be visible in the same point). Lines were indicated before, so I want to write proper LISP expression without indicating them again. What is proper form of line command?
(command "_line" ???????? "")
Pawel Klosowski
Solved by Kent1Cooper. Go to Solution.
Yup, both codes work from Kent and Gatsy. two different approach same result
wanted to do one myself, but as you can see...
well, learn new things everyday.
