I feel like this is a simple request, but I'm not at all familiar with LISP programming... Would appreciate any help you can offer.
I'd like a command, "bak," which will do the following:
1. Check if "bak" folder exists in directory of current drawing.
2. If so, keep going. If not, create directory.
3. Save a copy of the current file to the "bak" directory, appending the current date and time to the file name.
The file that remains open at the end of command should still be the original (un-archived) version.
Many thanks in advance!
Solved by Lee_Mac. Go to Solution.
Solved by pbejse. Go to Solution.
Christmas comes early. See Autolisp program below. Only issue is I had to use "-" as a delimeter for the date and "." as a delimeter for the time. Autocad does not accept "\" or ":" in file names. Give it a try. Any issues, please let me know
BAK.LSP l. gabriel 12/23/11
;object: to create archive files in "current directory\BAK\filename date time.dwg
; requested by mnilson
;Date Function
(defun TODAY ( / d yr mo day)
(setq d (rtos (getvar "CDATE") 2 6)
yr (substr d 3 2)
mo (substr d 5 2)
day (substr d 7 2)
(setq str (strcat mo "-" day "-" yr))
(setq str str)
;Time Function
(defun TIME ( / d hr m s)
hr (substr d 10 2)
m (substr d 12 2)
s (substr d 14 2)
(setq str (strcat hr "." m "." s))
(setq str str)
;Main Program
(defun c:BAK()
(setq directory (strcat (getvar "DWGPREFIX") "BAK"))
(if (= (findfile directory) nil)
(vl-mkdir directory)
(setq archivename (strcat (substr (getvar "DWGNAME") 1 (- (strlen (getvar "DWGNAME")) 4)) " " (TODAY) " " (TIME)))
(command "-WBLOCK" (strcat directory "\\" archivename) "*")
Thanks much! That appears to do the trick, even with civil 3d objects and data references! I'm curious what made you choose wblock as opposed to some form of "save as"? Only follow-up question is if there's a way to automatically accept ("Yes") the Autodesk Map Info prompt? Thanks again.
@mnilson wrote:I feel like this is a simple request, but I'm not at all familiar with LISP programming... Would appreciate any help you can offer.
Two thiings:
You can "copy" the current file name to the folder "bak" on its last saved state or
to ensure you have the latest copy, you can invoke "saveas" to that folder and revert it back to its orignal name and folder
Which one do you prefer?
pbejse - The first... The intent is to simplify an archive process, since users sometimes realize that they neeed to do a backup only after getting in and making a few changes... So copying / renaming the last saved state, then reverting to the original file name and directory would seem appropriate.
@mnilson wrote:pbejse - The first... The intent is to simplify an archive process, since users sometimes realize that they neeed to do a backup only after getting in and making a few changes... So copying / renaming the last saved state, then reverting to the original file name and directory would seem appropriate.
One more question? How ae you planning to invoke this routine? during startup? or a call from commnad prompt?
call from command prompt. ideally, "bak"
@mnilson wrote:call from command prompt. ideally, "bak"
Try this:
(defun c:Bak (/ aDoc Path fn p) (vl-load-com) (cond ((and (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (not (eq (setq fn (vla-get-fullname aDoc)) "")) (progn (if (member "BAK" (mapcar 'strcase (vl-directory-files (setq p (vla-get-path aDoc)) nil -1) ) ) (setq path (strcat (vla-get-path aDoc) "\\Bak\\")) (vl-mkdir (setq path (strcat (vla-get-path aDoc) "\\Bak\\")) ) ) path ) (vl-file-copy fn (strcat path (vla-get-name aDoc))) ))) (princ (if p (strcat "\n" path (vla-get-name aDoc)) "\nDrawing never been saved")) (princ) )
If succesfulll, the full path will be shown on the command prompt:
Thank you both for your help... I can see benefits to both of these routines and plan to work with them more after the holidays. Many thanks, and Merry Christmas / happy holidays!
@mnilson wrote:Thank you both for your help... I can see benefits to both of these routines and plan to work with them more after the holidays. Many thanks, and Merry Christmas / happy holidays!
Happy Holidays to you too..
BTW: can you handle the Date and Tiem Stamp suffix on the filename?
Anyhoo:
(vl-file-copy fn
(setq path (strcat path
(vl-filename-base fn) "_"(strcase (menucmd "M=$(edtime,$(getvar,date),MO-DD-YY-H_MM-am/pm)")) ".dwg" )))
(print
(if p
path
(princ)
Have fun
My version:
(defun c:bak nil (cond ( (= 1 (getvar 'DWGTITLED)) (vl-mkdir (strcat (getvar 'DWGPREFIX) "Bak")) (vl-file-copy (strcat (getvar 'DWGPREFIX) (getvar 'DWGNAME)) (strcat (getvar 'DWGPREFIX) "Bak\\" (cadr (fnsplitl (getvar 'DWGNAME))) (menucmd "m=$(edtime,$(getvar,DATE), YYYY-MO-DD HH-MM)") ".dwg" ) ) (princ "\nBackup Complete.") ) ( (princ "\nDrawing not Saved.") ) ) (princ) )
Thanks! I was going to cut and paste to get the date function in, but this does the trick! Great website, Lee Mac... I just poked around a bit and have already learned something!
I appreciate all the help you folks offer to non-programmers such as myself! Now if only I had asked this question a couple years ago when I first thought about it!
Glad it worked out for you. I chose "wblock" because it allows me to create the archive file without leaving the orignal drawing file. "Save As" keeps the saved file on the screen and closes the original.
I looked over the alternate program and it looks interesting as well. One day I will try to get into Vlisp functions, but after using the original Autolisp function for over 20 years, old habits are hard to break.
Always goes to show there is a more than one solution to any problem
pbejse wrote:Happy Holidays Lee Mac.
Thanks pbejse, same to you and yours
mnilson wrote:Thanks! I was going to cut and paste to get the date function in, but this does the trick! Great website, Lee Mac... I just poked around a bit and have already learned something!
Thanks mnilson! I'm delighted that you find my site beneficial, and of course, if you find anything on there that you don't understand, I'd be happy to put together an explanation for you.
Merry Christmas and Best Wishes for the New Year,
Lee
@pbejse wrote:....
....to ensure you have the latest copy, you can invoke "saveas" to that folder and revert it back to its orignal name and folder....
@Anonymous wrote:
....I chose "wblock" because it allows me to create the archive file without leaving the orignal drawing file. "Save As" keeps the saved file on the screen and closes the original.
It looks like there's a solution already using other methods, but just for your information / future reference:
There is a not-very-well-known command called plain SAVE [not to be confused with SAVEAS, nor with QSAVE, which is actually what you get from the toolbar disk icon and the so-called "Save" item on the File pull-down menu].
SAVE is somewhat like SAVEAS in that it creates another drawing file out of the one you're in, but whereas SAVEAS leaves you in the new file, SAVE keeps you in the old one. There's no need to revert back to it, as you would need to do if you used SAVEAS, because you never leave it -- you just make a copy of it elsewhere. And it's simpler than Wblock, because it requires no object selection -- it will do directly just what lgabriel describes as a reason for using Wblock: "create the archive file without leaving the original drawing file."
You have a point there kent, but by doing so it will save a copy on its current state which means its will not be a copy of the original "unsaved" state.
Hence i opted for vl-file-copy, however its ture only when the user hasnt invoke a save at all during the current session.
with that condition a reactor comes to mind.
BTW:
Make sure you set expert to 5 to suppress the prompt " Do you want to replace it? <N>"
EDIT: Better yet... make a copy of the ".bak" fie (if it exist) l to ".dwg" a small tweak on the updated code can achived that.
(vl-file-copy
(if (setq fnb (findfile (strcat (cadr (fnsplitl fn)) ".bak")))
fnb fn) ....
