Under the Custom tab of the Proerties dialog, I create a field ("Project")
and assign the value "Heartbreak Hotel" to the current drawing. Save and
close then open Acad. When I go to Design Center's Find dialog --- Look for
drawings, then the Drawing tab. Search for the word Heartbreak. But what
category do I select for In the fields category?
Dave P.
"Allen Johnson"
wrote in message
news:D9F2916880C7655EF1C121DC3FA34295@in.WebX.maYIadrTaRb...
> Setting Custom fields (or other fields) in the DwgProps
> Custom Tab (Drawing Properties Dialog Box)
> Provides ten custom fields for assigning names and values. For example,
you
> could create a custom field called "Project" and assign the actual project
> name as the value. To ensure that all your drawings use the same custom
> field names, you could create the custom fields in your drawing templates.
> The custom fields can be used in searches to help locate a drawing, such
as
> when you use the Find dialog box in AutoCAD® DesignCenterT.
> AutoCAD also provides access to the properties data using programming
> interfaces, such as AutoLISP®.
> So how do you set the Custom fields (or other fields) in the DwgProps
dialog
> though AutoLISP?
