New Member
parker.depriest
Message 1 of 3 (567 Views)
Set MLeader to Existing MLeader Style via LISP
567 Views, 2 Replies
12-11-2012 11:38 AM
I am trying to create a lisp routine that sets all existing MLEADERs to a certain pre-set MLEADERSTYLE, the equivalent of doing a Quick Select for Mleaders, and setting the style under the properties window.
I was able to write a similar routine that selects all dimensions and sets them to a certain DIMSTYLE, using entmod and DXF code 3 for dimstyle.  So far, I have not been able to find a group code for MLEADERSTYLE
 Any help would be greatly appreciated!
(defun C:dimstylechange (/ ENTITIES NO_OF_ENTITIES SSPOSITION ENTITY_NAME
OLD_ENTLIST NEW_STYLE NEW_ENTLIST)
(setvar "CMDECHO" 0)
(setq ENTITIES (ssget "X" '((0 . "DIMENSION"))))
(setq NO_OF_ENTITIES (sslength ENTITIES))
(setq SSPOSITION 0)
(repeat NO_OF_ENTITIES
;***CHANGE STYLE***
(setq ENTITY_NAME (ssname ENTITIES SSPOSITION))
(setq OLD_ENTLIST (entget ENTITY_NAME))
(setq OLD_STYLE (assoc 3 OLD_ENTLIST))
(setq NEW_STYLE (cons 3 "BCR 11x17"))
(setq NEW_ENTLIST (subst NEW_STYLE OLD_STYLE OLD_ENTLIST))
(entmod NEW_ENTLIST)
;***CHANGE LAYER***
(setq OLD_STYLE (assoc 8 OLD_ENTLIST))
(setq NEW_STYLE (cons 8 "DIM"))
(setq SSPOSITION (1+ SSPOSITION))
(command ".CHPROP" ENTITIES "" "C" "BYLAYER" "LT" "BYLAYER" "")
(princ (strcat "\n..." (rtos NO_OF_ENTITIES 2 0) " Dimension(s) changed..."))
(setvar "CMDECHO" 1)
(princ)
Kent1Cooper
Message 2 of 3 (547 Views)
Re: Set MLeader to Existing MLeader Style via LISP
12-11-2012 01:09 PM in reply to: parker.depriest
parker.depriest wrote:
....  So far, I have not been able to find a group code for MLEADERSTYLE
I don't have MLeaders [too old a version of AutoCAD], but I wonder whether that might be available with a little less work as a VLA Property.  Try drawing an MLeader [so it's the last thing in the drawing], then doing:
(vlax-dump-object (vlax-ename->vla-object (entlast)))
and see whether any of the listed Properties contains the current style.  [For Text and Mtext and Dimensions, the Property is called "StyleName", and it could very well be the same for MLeaders.]  If it does, you can use a (vla-put...) operation on a vla-object conversion of each MLeader found, instead of the whole (entget)/(subst)/(entmod) procedure.
Kent Cooper
Distinguished Contributor
phanaem
Message 3 of 3 (539 Views)
12-11-2012 02:29 PM in reply to: parker.depriest
How often do you need to do that? Maybe a Quick Select and change style in properties dialog is enough.
But if you have some reasons to use lisp, try this:
(defun C:TEST ( / *error* acDoc l new e ss)
  (setq acDoc (vla-get-activeDocument (vlax-get-acad-object)))
  (vla-StartUndoMark acDoc)
  (defun *error* (msg)
    (princ msg)
    (vla-EndUndoMark acDoc)
  (if
    (ssget "_X" '((0 . "MULTILEADER")))
     (progn
       (princ "\n\n\n****Mleader Styles****\n\n")
       (setq l (mapcar
                 (function
                   (lambda (s)
                     (princ (strcat "   " (cdr s) "\n"))
                     (cdr s)
                 (vl-remove-if
                   '(lambda (x) (/= (car x) 3))
                   (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE")
       (textscr)
       (if
         (member (setq new (getstring T "\nEnter new style name: ")) l)
          (progn
            (vlax-for e (setq ss (vla-get-ActiveSelectionSet acDoc))
              (vla-put-StyleName e new)
            (vla-delete ss)
          (princ "\nStayle name not found.")
       (graphscr)
  (princ)
You are not logged in.
Ask the Community
