Could someone tweak this routine to...
1. use the preset pagesetup name "pdf 30x42" rather than prompting for the
name
2. use the current layout rather than prompting for All or Current
BTW - Thanks Jason P. for the usefull code
Ken
; Jason Piercey . May 16th, 2003
; assign a pagesetup to a layout
; [layout] - string, layout name
; [setup] - string, pagesetup to assign
; return: T or nil
(defun putPagesetup (layout setup / layouts plots)
(defun item-p (collection item)
(if
(not
(vl-catch-all-error-p
(vl-catch-all-apply
'(lambda () (setq item (vla-item collection item))))))
item
(and
(or *acad* (setq *acad* (vlax-get-acad-object)))
(or *doc* (setq *doc* (vla-get-activedocument *acad*)))
(setq layouts (vla-get-layouts *doc*))
(setq plots (vla-get-plotconfigurations *doc*))
(setq layout (item-p layouts layout))
(setq setup (item-p plots setup))
(not (vla-copyfrom layout setup))
(defun massoc (key alist / x nlist)
(foreach x alist
(if (eq key (car x))
(setq nlist (cons (cdr x) nlist))
(reverse nlist)
; Return: list of all pagesetups defined in the current drawing or nil
(defun getPagesetups ()
(massoc 3 (dictsearch (namedobjdict) "Acad_PlotSettings"))
; Jason Piercey . May 19th, 2003
; assign pagesetup to layout(s)
; LIMITED testing
; written for Shawn McDonald
(defun c:psetup (/ lst page res)
(setq lst (mapcar 'strcase (getPagesetups)))
(while (not page)
(setq page (strcase (getstring T "\nspecify pagesetup to apply: ")))
(if (or (= "" page) (not (member page lst)))
(progn (princ "\npagesetup not found") (setq page nil))
(initget "All Current")
(if
(not
(setq
res
(getkword
"\n[All/Current]apply pagesestup to which layout(s)
(setq res "All")
(if (= "All" res)
(foreach x (layoutlist) (putPagesetup x page))
(putPagesetup (getvar "ctab") page)
(princ "\nFinished")
(princ)
