I am pretty sure this can be done but I dont know VLAX commands well enough to do it.
I want to set all the layers on all nested xref's to color 8. Does any know how/if this can be done?
Thanks.
Solved by pbejse. Go to Solution.
@Kent1Cooper wrote:....
(not (wcmatch (cdr (assoc 2 (entget item))) "`*D*,`*X*"))
....[The (wcmatch) checking for "`*D*,`*X*" is to determine that an item is not a Dimension or old-style Hatch pattern "block" -- use string "`*D*,`*X*,`*U*" to also ignore anonymous Blocks.]
Overdid it a little -- the *D is only applicable to distinguish Dimensions when stepping through the "block" table [as in the routine I stole some of this code from], not when stepping through the entities in a Block definition [where Dimensions would not be "INSERT" objects]. That line can be:
(not (wcmatch (cdr (assoc 2 (entget item))) "`*X*"))
and is only needed at all if you might sometimes encounter old-style Hatch patterns. If not, you could set the 'found' variable with just this:
(setq found (= (cdr (assoc 0 (entget item))) "INSERT"))
@Lee_Mac wrote:
@Kent1Cooper wrote:
I don't think you have understood my function Kent; ....
Your function is checking whether a Block Definition CONTAINS nested Block References.
My function is checking whether a Block Reference appears nested within another Reference.
Hence, for this task, you can use my function test whether a particular XRef has a nested reference.
I did misunderstand -- a semantic issue. To my mind, the wording "a particular XRef has a nested reference" or "the supplied block name has nested references" means that it "contains" or "includes" one [or more] nested things within it, not that it "appears nested within another Reference" [for which I would use the wording that it is a nested reference]. If it really means the latter, forget anything in my replies based on the former interpretation, but just know that the meaning is not unambiguous.
@Kent1Cooper wrote:I did misunderstand -- a semantic issue. To my mind, the wording "a particular XRef has a nested reference" or "the supplied block name has nested references" means that it "contains" or "includes" one [or more] nested things within it, not that it "appears nested within another Reference" [for which I would use the wording that it is a nested reference].
But using the wording 'is a nested reference' is incorrect, since the block itself is not a reference and furthermore, not all references may be nested.
In my opinion, the function description is clear:
;; HasNestedReferences-p - Lee Mac ;; Returns T if the supplied block name has references ;; which are nested within other block references.
