I need the same funcionality as in code below, but without using "command".
The main idea is alowed user to modify Existing Selection Set.
(defun gt:ss->lst (a:ss / i lst ) ;_ / (setq i 0) (if a:ss (progn (repeat (sslength a:ss) (setq lst (cons (ssname a:ss i) lst) i (1+ i) ) ;_ setq ) ;_ repeat (reverse lst) ) ;_ progn ) ;_ if ) ;_ defun gt:ss->lst (defun gt:ss_modify (a:en-lst / ) ;_ / ;;create Selection set (setq ss2 (ssadd)) (foreach f:en a:en-lst (ssadd f:en ss2) ) ;_ foreach ;;Run command and fill with initial content (command "_select" ss2) ;;Alow the user to modify the contents (while (/= (getvar "cmdnames") "") (command pause) ) ;_ while ;;get back the list of enames from modified selection set (setq ss3 (ssget "_P")) (setq ss3-lst (gt:ss->lst ss3)) ) ;_ defun gt:ss_modify (defun tst:gt:ss_modify ( / ) ;_ / (gt:ss_modify (gt:ss->lst (ssget))) ) ;_ defum tst:gt:ss_modify
any idea?
Thanks in advance
Ales Stanek
i do not exectly understand what you are trying to do but
why (ssget) is not sufficient
as far as i understand SELECT command and (ssget) can do the same job?!
Moshe
@Anonymous wrote:....
please, I really need remove the command. Could somebody help me with that.
I looked at that a little. If by "modify" you mean you want to be able to both add to and remove from a pre-existing selection set, within the same operation, I didn't find a way other than with the Select command, which is why I didn't reply yesterday. If all you want to be able to do is add to a selection set, then I think that can be done without (command).
Hi Kent1Cooper,
Yes you are right. I prepared for user pre existing selection set. User can added or removed some entities and confirmed the select.
But the fact that without command isn't possible that made. make me very sad.
Thanks for answer
Aleš Staněk
@Anonymous wrote:Hi Kent1Cooper,
I wouldn't guarantee that it can't be done without (command) -- I just haven't found a way [yet?]. It might not be too hard if you don't mind doing all add and remove selections as single items, with which a routine could use (ssadd) and (ssdel). But if you want all the usual selection options like Window/Crossing, Fence, Multiple, etc., I think that would be more difficult.
Hi Kent1Cooper
you are right again, I plan alow to user used select mode like crosing and etc. 🙂
Best Regards
Aleš
This is an atempt to imitate "Select" command, including prompts.
I rewrote gs:ss-modify routine (btw, gs: seems to me as a signature. If it is someone else's work, you should include info about the original coder. If it is yours, my appologise)
;rewriten by Stefan M., 07.IX.2012
(defun gt:ss_modify (a:en-lst / *error* e enter gr_point i lt p1 p2 p3 prev reason sel_mode ss value) (defun *error* (msg) (if msg (princ msg)) (redraw) (foreach x a:en-lst (redraw x 4)) ) (grread T 5) (foreach x a:en-lst (redraw x 3)) (princ "\nSelect objects: ") (while (not enter) (setq gr_point (grread T 5 (if sel_mode 1 2)) reason (car gr_point) value (cadr gr_point) ) (cond (sel_mode (redraw) (cond ((= reason 3) (if (setq ss (ssget sel_mode p1 value)) (progn (setq prev 0 i -1 ) (repeat (sslength ss) (setq i (1+ i) e (ssname ss i) ) (if (member e a:en-lst) (setq prev (1+ prev)) (progn (redraw e 3) (setq a:en-lst (cons e a:en-lst)) ) ) ) (princ (strcat (itoa (1+ i)) " found" (if (> prev 0) (strcat " (" (itoa prev) " duplicate), ") ", " ) (itoa (length a:en-lst)) " total\nSelect objects: " ) ) ) (princ "0 found\nSelect objects: ") ) (setq sel_mode nil) ) ((= reason 5) (if (minusp (- (car value) (car p1))) (setq sel_mode "C" lt 1) (setq sel_mode "W" lt 0) ) (grdraw p1 (setq p2 (list (car value) (cadr p1))) 7 lt) (grdraw p2 value 7 lt) (grdraw value (setq p3 (list (car p1) (cadr value))) 7 lt) (grdraw p3 p1 7 lt) ) ) ) ((or (member value '(13 32)) (member reason '(11 12 25))) (setq enter t)) ((= reason 3) (if (setq e (nentselp value)) (progn (setq e (car (if (= (length e) 2) e (last e)))) (princ "1 found") (if (member e a:en-lst) (princ " (1 duplicate)") (progn (setq a:en-lst (cons e a:en-lst)) (redraw e 3) ) ) (princ (strcat ", " (itoa (length a:en-lst)) " total\nSelect objects: ")) ) (progn (princ "Specify opposite corner: ") (setq sel_mode "W" p1 value ) ) ) ) ) ) (*error* nil) a:en-lst )
Hi phaneam,
thanks for respons, I going to test it today. The code is main. And the signiture insn't GS: but GT: and means "GLOBAL TOOLS"
Aleš Staněk
