Visual LISP, AutoLISP and General Customization
Selecting block parameter whit lisp
8 REPLIES 8
Message 1 of 9
Thomas.l
949 Views, 8 Replies
Hi
I am working on a lisp routine that automaticaly inserts a parameter in a block and then ads a stretch command to it. But the problem is that for the stretch command u need to select the drawn parameter. So my plan was to get the name of this parameter (car (entsel)) and feet it to my lisp program. But when i do that it doesn't work because autocad demands a parameter.
Hope somebody can help me whit this problem
Regards
Thomas
8 REPLIES 8
Message 2 of 9
pbejse
in reply to: Thomas.l
@Thomas.l wrote:
Hi
Regards
Thomas
Look into GetDynamicBlockProperties method
Message 3 of 9
Hallex
Try something like this
(setq propname "Wall Height distance") ;<-- property name
(setq propval 1200.0);<-- propert value of double
 (if (setq ss (ssget "_:S" '((0 . "INSERT")(2 . "`*U*,*"))))   ;<-- to change dynamic blocks
  (progn
;get vla-object selected
 (setq blkobj (vlax-ename->vla-object (ssname ss 0)))
;retrieve desired property list
         (setq proplst (vl-remove-if-not '(lambda (x) (eq (vla-get-PropertyName x) propname ))
     (vlax-invoke blkobj 'getdynamicblockproperties)))
;get dynamic property we need
    (setq prop (car proplst))
;set desired property value to this property
     (vla-put-value prop (vlax-make-variant propval 5)) ;<-- 5 is for double value, see Help file
      (vla-update blkobj);<-- update selected block
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 9
Thomas.l
in reply to: Hallex
wel that is a piece of interesting code.
But it isn't exactly what i am looking for.
I simply want to be able to ad a stretch action to a stretch parameter whitout having to quite my lisp routine.
Regards
Thomas
Message 5 of 9
pbejse
Regards
Thomas
Share your code then we'll  incorporate the same method on your routine
Message 6 of 9
Thomas.l
in reply to: pbejse
This should give you the idea
(setq ang 0)
(defun c:az ()
  (setq pt1 (getpoint "define insertion point:")
	pt2 (polar pt1 (/ (* ang 2 pi) 360) 100))
  (command "bparameter" "linear" pt2 pt1 "500,0" "1")
  (command "baction")
(defun c:aq ()
  (setq ang (+ ang 1))
  (command "bvstate" "set" ang))
 these functions work for block in attachemend when opend in block editor.
And thank you both for helping!
Regards
Thomas
Message 7 of 9
pbejse
 Regards
Thomas
Try this way to select the parameter
(defun c:az ()
  (command "baction" (nentselp pt1)) ;<--- you do the rest
Message 8 of 9
Thomas.l
in reply to: pbejse
Thank you very much that was exactly what i was looking foor.
I realy don't know how i could mis that.
Regards Thomas
Message 9 of 9
pbejse
Regards Thomas
You're welcome
Glad i could help
Cheers
”Boost
