Hi
I am working on a lisp routine that automaticaly inserts a parameter in a block and then ads a stretch command to it. But the problem is that for the stretch command u need to select the drawn parameter. So my plan was to get the name of this parameter (car (entsel)) and feet it to my lisp program. But when i do that it doesn't work because autocad demands a parameter.
Hope somebody can help me whit this problem
Regards
Thomas
Solved by pbejse. Go to Solution.
@Thomas.l wrote:Hi
Regards
Thomas
Look into GetDynamicBlockProperties method
Try something like this
(setq propname "Wall Height distance") ;<-- property name (setq propval 1200.0);<-- propert value of double (if (setq ss (ssget "_:S" '((0 . "INSERT")(2 . "`*U*,*")))) ;<-- to change dynamic blocks (progn ;get vla-object selected (setq blkobj (vlax-ename->vla-object (ssname ss 0))) ;retrieve desired property list (setq proplst (vl-remove-if-not '(lambda (x) (eq (vla-get-PropertyName x) propname )) (vlax-invoke blkobj 'getdynamicblockproperties))) ;get dynamic property we need (setq prop (car proplst)) ;set desired property value to this property (vla-put-value prop (vlax-make-variant propval 5)) ;<-- 5 is for double value, see Help file (vla-update blkobj);<-- update selected block ) )
~'J'~
wel that is a piece of interesting code.
But it isn't exactly what i am looking for.
I simply want to be able to ad a stretch action to a stretch parameter whitout having to quite my lisp routine.
Regards
Thomas
@Thomas.l wrote:wel that is a piece of interesting code.
Regards
Thomas
Share your code then we'll incorporate the same method on your routine
This should give you the idea
(setq ang 0) (defun c:az () (setq pt1 (getpoint "define insertion point:") pt2 (polar pt1 (/ (* ang 2 pi) 360) 100)) (command "bparameter" "linear" pt2 pt1 "500,0" "1") (command "baction") ) (defun c:aq () (setq ang (+ ang 1)) (command "bvstate" "set" ang))
these functions work for block in attachemend when opend in block editor.
And thank you both for helping!
Regards
Thomas
@Thomas.l wrote:This should give you the idea
Regards
Thomas
Try this way to select the parameter
(defun c:az ()
(command "baction" (nentselp pt1)) ;<--- you do the rest
Thank you very much that was exactly what i was looking foor.
I realy don't know how i could mis that.
Regards Thomas
