- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Select line and get endpoint?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can I select a line and get the nearest endpoint so I can do something to the line using the endpoint as a base?
Got an idea it will include an ssget and an osnap "end" in the code, but not too sure how to put it together.
Re: Select line and get endpoint?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Gordon_S wrote:Can I select a line and get the nearest endpoint so I can do something to the line using the endpoint as a base?
You could do it with (ssget), but for a single object, (entsel) is a little simpler. In simplest terms, you can do this:
(setq
linesel (entsel "\nSelect Line nearer desired endpoint: ")
endpt (osnap (cadr linesel) "_end"); apply Osnap to selection point [second item in list returned by (entsel)]
You can get much fancier about it if you want, e.g.:
Test whether something was actually selected;
Test whether what was selected is, in fact, a Line;
If not either of the above, ask again rather than give up;
Set the APERTURE System Variable temporarily equal to the PICKBOX System Variable, which will avoid the possibility that something else within Osnap-aperture range of the pick point has an endpoint closer than the Line's.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
(setq
Then, the entity name of the Line would be (car linesel) [first item in list returned by (entsel)], which you could save into a variable for use in whatever you want to do with it, or just use it directly if you don't need it enough times for the variable to be a code savings.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Excellent! That's exact;y what I needed - I'll be able to put my little routine together now.
Thanks Kent, very helpful.
Gordon
