Visual LISP, AutoLISP and General Customization
Select Layer by Color Lisp
9 REPLIES 9
Message 1 of 10
3728 Views, 9 Replies
I am interested in a program that can select layers by its color, and then change those layers to a different color and add a prefix of Z- in front of those layers.
Example:
Layer Names:   Layer Color:   New Layer Names:   New Layer Color:
Wall                         2                    Z-Wall                       100
Berm                       2                     Z-Berm                     100
Fence                     2                     Z-Fence                   100
I found a program (below) that works pretty close to what I am looking for but not quite.
;;;  Change the color of a layer to another color by Jeff Mishler July 9, 2003
;;;  Usage - (lay_col_chg oldcolor newcolor
;;;  example: Command: (lay_col_chg 142 100)
(defun lay_col_chg (oldcolor newcolor / layers)
(vl-load-com)
(setq layers (vla-get-layers
(vla-get-activedocument
(vlax-get-acad-object))))
(vlax-for x layers
(if (= oldcolor (vla-get-color x))
(vla-put-color x newcolor)
(princ)
Thanks ahead of time for your help.
9 REPLIES 9
Message 2 of 10
Lee_Mac
The most intuitive way would be to iterate through the Layer Collection and use a conditional statement to test for the desired properties of the layers to be changed:
e.g.:
(defun c:dolayers ( / name )
    (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
        (if
            (and
                (= 2 (vla-get-color layer))
                (not (wcmatch (setq name (vla-get-name layer)) "Z-*"))
                (not (tblsearch "LAYER" (setq name (strcat "Z-" name))))
            (progn
                (vla-put-color layer  100)
                (vla-put-name  layer name)
    (princ)
(vl-load-com) (princ)
Message 3 of 10
in reply to: Lee_Mac
Lee, thanks for your reply and code.  I should have elaborated my requests a little further.  I was hoping for something more like prompting me for the color of the existing layers and also for the color of the new layer.  On another note I took a look at your layerextract tool to see if I could use it for this instance, which didn't look like I could, but nice program though.
Message 4 of 10
Lee_Mac
No worries, try something like this:
(defun c:dolayers ( / c1 c2 nm pr  )
    (if
        (and
            (princ "\nSelect Existing Layer Color...")
            (princ)
            (setq c1 (acad_colordlg 7 nil))
            (princ "\nSelect New Layer Color...")
            (princ)
            (setq c2 (acad_colordlg 7 nil))
            (setq pr (getstring t "\nSpecify Layer Prefix: "))
            (if
                (and
                    (= c1 (vla-get-color layer))
                    (not (wcmatch (setq nm (vla-get-name layer)) (strcat pr "*")))
                    (not (tblsearch "LAYER" (setq nm (strcat pr nm))))
                (progn
                    (vla-put-color layer c2)
                    (vla-put-name  layer nm)
    (princ)
Thanks azrdgldr, I'm glad you like the program - unfortunately it can only to be used for extracting data however Smiley Wink
Message 5 of 10
Works great.  Thanks for your help on this.
Message 6 of 10
Lee_Mac
You're welcome azrdgldr Smiley Happy
Message 7 of 10
I have only stuck my toes in to check the temperature when it comes to Vl- commands and their usage.  You and Kent make this stuff look so easy and I do mean easy.  I still consider myself a hacker at this even though I have written quite a few programs.  I know now that I just have to jump in no matter what and see if I sink or swim in VL-.  Thanks again.
Message 8 of 10
Lee_Mac
Thanks azrdgldr Smiley Happy
Once you have a basic understanding of the underlying structure of the AutoCAD Object Model*, and how to work with properties and methods derived from objects in the model, the best way to learn is to experiment and post a question when you get stuck; then learn from the mistakes that you make.
Studying the code posted by others on the forums is also a great benefit, (just make sure that you study code from a good source Smiley Wink), but when you attempt a program yourself you realise where your knowledge is lacking and the parts that you need to study some more.
*For what its worth, I wrote a brief intro to the Object Model in a post at CADTutor here, I'm not sure of your level at VL programming, but maybe it will be of some benefit to your learning.
Hope this helps,
Lee
Message 9 of 10
j_p_salvador
Hi @Lee_Mac ,
Can you write me a code to select all color 254 and delete.
Thanks in advace.
Message 10 of 10
Sea-Haven
in reply to: j_p_salvador
To quote post here.
Studying the code posted by others on the forums is also a great benefit, just make sure that you study code from a good source.
”Boost
