devitg
Message 11 of 23 (177 Views)
Re: Select Arcs by with Normal Z = -1
02-12-2013 06:35 AM in reply to: devitg
at least , not ay least
Kent1Cooper
Message 12 of 23 (175 Views)
02-12-2013 06:37 AM in reply to: Kent1Cooper
Kent1Cooper wrote:
.....  I gave a quick try to Mirror3D, but I must have been misunderstanding how to define the axis, because it didn't work.  ....
EDIT:  NO, hold off on that [I hadn't done something I should have....].  I was trying the Object option, which works manually, but doesn't accept an entity name in a (command) function.
Kent Cooper
hmsilva
Message 13 of 23 (163 Views)
02-12-2013 07:10 AM in reply to: bhaushalter1
normal z=-1
command: flatten
nornal z = 1
Henrique
devitg
Message 14 of 23 (162 Views)
02-12-2013 07:13 AM in reply to: hmsilva
Just SIMPLE , thanks
Active Member
bhaushalter1
Message 15 of 23 (158 Views)
02-12-2013 07:18 AM in reply to: devitg
Thanks again Guys for your invaluable help. I ended up finding a program and applying devitg's filter suggestion and it works great!!!!
(defun c:fliparcs3 (/ ss hpi en el)
  (setq
    ss (ssget "X" (list (cons 0 "ARC") (cons 210 '( 0 0 -1))))
    hpi (* 0.5 pi)
  (cond
      (not (null ss))
      (repeat (sslength ss)
        (ssdel (setq en (ssname ss 0)) ss)
        (setq el (entget en))
        (entmod
          (mapcar
            (function
              (lambda (x / g)
                (setq g (car x))
                (cond
                  ((= g 10) (cons 10 (mapcar '* (list -1.0 1.0 -1.0) (cdr x))))
                  ((= g 210) (cons 210 (mapcar '- (cdr x))))
                  ((= g 50) (cons 50 (+ hpi (- hpi (cdr (assoc 51 el))))))
                  ((= g 51) (cons 51 (+ hpi (- hpi (cdr (assoc 50 el))))))
                  (t x)
            el
      (princ "\nDone")
    (t (princ "\nNothing selected"))
  (princ)
hmsilva
Message 16 of 23 (156 Views)
02-12-2013 07:22 AM in reply to: devitg
You're welcome, devitg
Active Member
bhaushalter1
Message 17 of 23 (149 Views)
02-12-2013 07:38 AM in reply to: hmsilva
hmsilva wrote:
normal z=-1
command: flatten
nornal z = 1
Henrique
I tried that originally but for some reason these DXF files will not convert to a joined polyline after using that command. If I flip the arcs with the normal z of -1 they will.
hmsilva
Message 18 of 23 (147 Views)
02-12-2013 07:46 AM in reply to: bhaushalter1
bhaushalter1,
just flatten and pedit...
Henrique
Active Member
bhaushalter1
Message 19 of 23 (137 Views)
02-12-2013 08:56 AM in reply to: hmsilva
hmsilva wrote:
bhaushalter1,
Henrique
Interesting... I must be doing something wrong. Im new to ACad.  Below are my steps:
Command: ucs
Current ucs name:  *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>: w
Command: plan
Enter an option [Current ucs/Ucs/World] <Current>:
Regenerating model.
Command: flatten
Select objects to convert to 2d...
Select objects: Specify opposite corner: 19 found
Select objects:
Remove hidden lines? <Yes>:
Command: pedit
Select polyline or [Multiple]:
Object selected is not a polyline
Do you want to turn it into one? <Y>
Enter an option [Close/Join/Width/Edit vertex/Fit/Spline/Decurve/Ltype
gen/Reverse/Undo]: j
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects: 1 found, 3 total
Select objects: 1 found, 4 total
Select objects: 1 found, 5 total
Select objects:
0 segments added to polyline
hmsilva
Message 20 of 23 (131 Views)
02-12-2013 09:23 AM in reply to: bhaushalter1
bhaushalter1,
in this example, in the pedit command, I used the option multiple to be faster, and in this way created two polylines
Command: ucs
<World>: w
Command: plan
Regenerating model.
Command: flatten
Select objects: all
19 found
Select objects:
Remove hidden lines? <No>:
Command: pe
PEDIT Select polyline or [Multiple]: Select polyline or [Multiple]: m
Select objects: all
19 found
Select objects:
Convert Lines, Arcs and Splines to polylines [Yes/No]? <Y>
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>:
17 segments added to 2 polylines
but if you select the objects in the orden which we want the polyline be joined, like the dwg I have attached you'll only get with one polyline
Command: pedit Select polyline or [Multiple]:
Select objects: Specify opposite corner: 13 found, 16 total
Select objects: 1 found, 17 total
Select objects: 1 found, 18 total
Select objects:
18 segments added to polyline
hope that helps
Henrique
You are not logged in.
Ask the Community
