Searching for dynamic blocks with visibility perimeter that is case sensitive
15 REPLIES 15
Message 1 of 16
paduch_chris
1385 Views, 15 Replies
This is a new thread to get a final solution instead of trolling another user's thread.
I've been getting help from @hmsilva who has helped create a routine to list all the dyanmic blocks in my drawing with a specific visibilty parameter name. The problem with the blocks that I'm trying to search for in my draiwng is that the visibility names are very similar with the only differences being CASE sensitivity (ie. OBJECT vs. Object). I'm very new to LISP so any help is greatly appreciated. Thanks in Advance.
Chris
(defun c:test (/ BNAME DATA E I PNAME SS VIS)
  (if (setq data nil
	    vis	 (getstring T "\nEnter the Visibility Parameter Name: ")
	    ss	 (ssget	"_X"
			(list (cons 0 "INSERT")
			      (cons 2 "`*U*")
    ;; setq
    (progn
      (repeat (setq i (sslength ss))
	(cond ((and (setq bname	(vla-get-EffectiveName
				  (setq	e (vlax-ename->vla-object
					    (ssname
					      ss
					      (setq i (1- i))
		    (setq Pname	(car (vl-remove-if-not
				       '(lambda	(j)
					  (eq (strcase (vla-get-PropertyName j))
					      (strcase vis)
				       (vlax-invoke e 'GetDynamicBlockProperties)
		    (not (member bname data))
	       (setq data (cons bname data))
	       (foreach itm data (print itm))
	);; cond
      );; repeat
    );; progn
  );; if
  (if (null data) (princ "\nBlock/Parameter Name not found"))
  (princ)
15 REPLIES 15
Message 2 of 16
hmsilva
in reply to: paduch_chris
Chris,
in order to make this "demo" case sensitive, just change
(eq (strcase (vla-get-PropertyName j)) (strcase vis))
to
(eq  (vla-get-PropertyName j) vis)
Look at the strcase function...
HTH
Henrique
Message 3 of 16
Lee_Mac
If I have understood the task correctly, I would suggest the following:
(defun c:test ( / bln idx lst obj par rtn sel )
    (cond
        (   (= "" (setq par (strcase (getstring t "\nEnter parameter name: ")))))
        (   (or (null (setq sel (ssget "_X" '((0 . "INSERT")))))
                (progn
                    (repeat (setq idx (sslength sel))
                        (if
                            (and
                                (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
                                (vlax-property-available-p obj 'isdynamicblock)
                                (= :vlax-true (vla-get-isdynamicblock obj))
                                (setq bln (vla-get-effectivename obj))
                                (not (member bln lst))
                            (progn
                                (if (vl-some
                                       '(lambda ( p ) (= par (strcase (vla-get-propertyname p))))
                                        (vlax-invoke obj 'getdynamicblockproperties)
                                    (setq rtn (cons bln rtn))
                                (setq lst (cons bln lst))
                    (null rtn)
            (princ (strcat "\nNo dynamic blocks found with parameter \"" par "\""))
        (   (foreach blk rtn (print blk)))
    (princ)
(vl-load-com) (princ)
Message 4 of 16
pbejse
@I've been getting help from @hmsilva who has helped create a routine to list all the dyanmic blocks in my drawing with a specific visibilty parameter name. The problem with the blocks that I'm trying to search for in my draiwng is that the visibility names are very similar with the only differences being CASE sensitivity (ie. OBJECT vs. Object). I'm very new to LISP so any help is greatly appreciated. Thanks in Advance.
Chris
Are you just after a "list" of DB's with target Visibility name? Or you need to process the blocks as well?
For the first option :
This approach searches the block table definiton rather than block entities
(defun c:DEmo  (/ blocks parname a blk Bnames dbp par)
;;; idea taken from  LMs' LM:getvisibilityparametername function      ;;;
;;	pBe Dec2013	;;;
      (setq blocks (vla-get-blocks
                         (vla-get-ActiveDocument
                               (vlax-get-acad-object))))
      (if
            (and
            (setq Bnames nil
                  parname
                       (strcase
                             (getstring
                                   t
            (while (setq a (tblnext "BLOCK" (null a)))
                  (setq blk (vla-item
                                  Blocks
                                  (setq bn (Cdr (assoc 2 a)))))
                  (if (and (setq dbp  (dictsearch
                                            (vlax-vla-object->ename
                                                  (vla-getextensiondictionary
                                                        blk))
                                            "ACAD_ENHANCEDBLOCK"
                           (setq dbp (assoc 360 dbp))
                           (= "BLOCKVISIBILITYPARAMETER"
                              (cdr (assoc 0
                                          (setq ent  (Entget
                                                           (Cdr dbp))))))
			(wcmatch
			      (Strcase
			            (setq par (cdr (assoc
			                                 301
			                                 ent))))
			      (strcase parname))
                        (setq Bnames (cons bn Bnames))
                      		Bnames));while
            (foreach bnm  Bnames
                  (print bnm))
           (princ (strcat "\nNo dynamic blocks found with parameter \"" parname "\""))
      (princ)
Holler  If you need to process the blocks than just making list Chris
HTH
Message 5 of 16
Lee_Mac
in reply to: pbejse
Great idea pbejse! - and thank you for the attribution. Smiley Wink
The code could also be written without using ActiveX, e.g.:
;; Prints the names of dynamic blocks which contain a visibility parameter
;; with parameter name equal to that specified by the user.
;; Lee Mac  -  2013-12-21  -  www.lee-mac.com
(defun c:getblockswithvispar ( / def dic par rtn )
    (if (/= "" (setq par (strcase (getstring t "\nEnter parameter name: "))))
        (progn
            (while (setq def (tblnext "block" (null def)))
                (if
                    (and
                        (setq dic
                            (cdr
                                (assoc 360
                                    (entget
                                        (cdr
                                            (assoc 330
                                                (entget
                                                    (tblobjname "block"
                                                        (cdr
                                                            (assoc 2 def)
                        (= par
                            (vl-some
                               '(lambda ( x )
                                    (if
                                        (and
                                            (= 360 (car x))
                                               (cdr (assoc 0 (entget (cdr x))))
                                        (strcase(cdr(assoc 301(entget(cdr x)))))
                                (dictsearch dic "acad_enhancedblock")
                    (setq rtn (cons (cdr (assoc 2 def)) rtn))
            (if rtn
                (princ
                    (strcat
                        "\nNo dynamic blocks found with visibility parameter \""
                        par
    (princ)
Message 6 of 16
hmsilva
in reply to: Lee_Mac
@ Lee_Mac
Nicely coded, Lee! Smiley Happy
@pbejse
Nice approach, pBe!
don't we need to go through all dxf 360 until we find the "BLOCKVISIBILITYPARAMETER" one? Smiley Wink
Cheers
Henrique
Message 7 of 16
paduch_chris
Hi All, Thanks so much for weighing in! I tried each of these solutions today and had mixed results. I'm going to reply to all in a single post so here it goes:
@HMSilva: Removing the strcase function worked in the original code, but it duplicated the listing of the blocks with the visibility parameter that I was searching. I'm wondering if it's searching for all blocks defined in the drawing including the "U" versions that occur when you adjust any dynamic block.  I tried your other version but it wasn't picking up the visability parameter.
@Lee_Mac Your versions both worked but they weren't case sensitve. I tried removing the strcase function but it wasn't working for me. I'm very new to lisp so if somone could break down what exactly is going on in the code, it would be much appreciated from a learning standpoint!
Also, I'm trying to make it loud and clear when the block visabilities are incorrect so I was trying to add and alert function instead of foreach (print blk), but I can't get the alert to do anything but a single block at a time. Instead of foreach, what should the function be? And if I don't want it to be a getstring with user input but a preset visability parameter, how do I do that? Thanks again all.
Chris
Message 8 of 16
hmsilva
@hmsilva: Removing the strcase function worked in the original code, but it duplicated the listing of the blocks with the visibility parameter that I was searching. I'm wondering if it's searching for all blocks defined in the drawing including the "U" versions that occur when you adjust any dynamic block.  I tried your other version but it wasn't picking up the visability parameter.
Chris,
the code at the #1 post (made from a pbejse code ), shouldn't duplicate the blocks "EffectiveName" and I can't reproduce that behavior, if possible, attach a sample dwg with some blocks to be able to test...
"...I tried your other version..."
The other version, was not posted by me, it's from pbejse, is a very well designed code, just need a small adjustment, and I am sure that pbejse will do that.
Henrique
Message 9 of 16
Lee_Mac
@hmsilva wrote:
@ Lee_Mac
Thank you Henrique! Smiley Happy
Sorry Chris, since most programs of this nature are usually written to be case-insensitive, I had overlooked the fact that you wanted the Visibility Parameter to exactly match the string entered by the user.
Please try the following code instead:
    (if (/= "" (setq par (getstring t "\nEnter parameter name: ")))
        (progn
                (if
                    (and
                        (setq dic
                            (cdr
                                (assoc 360
                                    (entget
                                        (cdr
                                            (assoc 330
                                                (entget
                                                    (tblobjname "block"
                                                        (cdr
                                                            (assoc 2 def)
                        (= par
                            (vl-some
                               '(lambda ( x )
                                    (if
                                        (and
                                            (= 360 (car x))
                                        (cdr (assoc 301 (entget (cdr x))))
                    (setq rtn (vl-list* "\n" (cdr (assoc 2 def)) rtn))
            (if rtn
                (alert
                    (apply 'strcat
                        (cons "The following blocks were found:\n" rtn)
                (princ
                    (strcat
                        par
    (princ)
Message 10 of 16
Lineabove
Lee Mac,
Any chance this could be revised to Prompt for which parameter you wish to search for rather than only the BLOCKVISIBILITYPARAMETER ?
Message 11 of 16
hmsilva
Nice one, Lee! Smiley Happy
Henrique
Message 12 of 16
bhull1985
in reply to: hmsilva
Henrique
Hello all,
what does that bit of code accomplish, i was intrigued but this is over my head---
still curious!
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
Message 13 of 16
hmsilva
in reply to: bhull1985
Hi Brandon,
with
using the vl-list* function, Lee built the rtn list without having to use twice the cons function...
(setq rtn (cons "\n" (cons (cdr (assoc 2 def)) rtn)))
HTH
Henrique
Message 14 of 16
Lee_Mac
Henrique
@Anonymous wrote:
Lee Mac,
I have a few more ideas for this program - I'll look to work on it when I have some more time Smiley Wink
Message 15 of 16
paduch_chris
This is perfect! Thanks so much! 🙂
Chris
Message 16 of 16
Lee_Mac
Chris
You're welcome Chris! Smiley Happy
”Boost
