I had tried to make a script to copy an attribute value from a block and paste the value in another attribute with a prefix say "x" in the same drawing.
Eg. Block "A" with attribute tag VALUE : ACAD. I want to take ACAD from Block A and paste it in Block B as XACAD. which is in the same drawing .
Can anyone help pls.
For what ACAD version? IOW, can you use fields? If so, you could paste a field code that pointed to the other block's attribute contents. This could be done programmatically but the field would maintain the relationship.
I'm not sure if you really need a script or if a LISP will do. so here is an example:
(DEFUN Get-Put-AttVal (TAG1 TAG2 BLOCK1 BLOCK2 / CNT EG EN ENT1 ENT2 ENTINFO KK KS SS SSET VAL) (IF (SETQ sset (SSGET "x" (LIST (CONS 2 BLOCK1) (CONS 410 (GETVAR 'ctab))))) (PROGN (SETQ cnt 0 ent1 (SSNAME sset cnt) ent2 (ENTNEXT ent1) entinfo (ENTGET ent2) ) (WHILE (AND ent2 (= "ATTRIB" (CDR (ASSOC 0 entinfo)))) (IF (= TAG1 (CDR (ASSOC 2 entinfo))) (PROGN (SETQ VAL (CDR (ASSOC 1 entinfo))) (SETQ ent2 nil) ) (PROGN (SETQ ent2 (ENTNEXT ent2)) (SETQ entinfo (ENTGET ent2)) ) ) ) ) (ALERT (STRCAT "ERROR: " BLOCK1 " Not Found!")) ) (IF (EVAL VAL) (IF (SETQ SS (SSGET "X" (LIST (CONS 0 "INSERT") (CONS 2 BLOCK2) (CONS 410 (GETVAR 'ctab))))) (PROGN (SETQ KK 0 KS (SSLENGTH SS) ) (WHILE (< KK KS) (SETQ EG (ENTGET (SSNAME SS KK))) (SETQ EN (ENTGET (ENTNEXT (CDR (ASSOC -1 EG))))) (WHILE (AND EN (/= (CDR (ASSOC 0 EN)) "SEQEND")) (IF (= (CDR (ASSOC 2 EN)) TAG2) (PROGN (SETQ EN (SUBST (CONS 1 VAL) (ASSOC 1 EN) EN)) (ENTMOD EN) (ENTUPD (CDR (ASSOC -1 EG))) (SETQ EN nil) ) (SETQ EN (ENTGET (ENTNEXT (CDR (ASSOC -1 EN))))) ) ) (SETQ KK (1+ KK)) ) ) (ALERT (STRCAT "ERROR: " BLOCK2 " Not Found!")) ) ) (PRINC) )
Simply use: (Get-Put-AttVal TAG1NAME TAG2NAME BLOCK1NAME BLOCK2NAME) and it can be added into a script.
I hope this is what you were looking for.
Here's an old program from my library to copy all attribute values from one block to many - it could quite easily be customised to copy specific attribute values to specific tags by adding some appropriate conditional statements:
;; Match Attribute Values - Lee Mac (defun c:mav ( / idx lst ss1 ss2 val ) (if (and (princ "\nSelect source block: ") (setq ss1 (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1)))) (princ "\nSelect blocks to match attributes: ") (setq ss2 (ssget "_:L" '((0 . "INSERT") (66 . 1)))) ) (progn (foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss1 0)) 'getattributes) (setq lst (cons (cons (strcase (vla-get-tagstring att)) (vla-get-textstring att)) lst)) ) (repeat (setq idx (sslength ss2)) (foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss2 (setq idx (1- idx)))) 'getattributes) (if (setq val (cdr (assoc (strcase (vla-get-tagstring att)) lst))) (vla-put-textstring att val) ) ) ) ) ) (princ) ) (vl-load-com) (princ)
