Visual LISP, AutoLISP and General Customization
Active Contributor
haynesc87
Message 1 of 8 (528 Views)
! Script Help Please - Linetype Replace
528 Views, 7 Replies
01-28-2013 10:14 AM
Hello all
The Situation is as follows :
I wish to have a script that can be run on 1000+ drawings to do the following :
Load a New Defined Linetype .... "NewLineType000"
Select all layers that = NOT Continuous & = Colour 8 > Replace Linetype with "NewLineType000"
Can anyone help me out please, many thanks in advance
Chris
diagodose2009
Message 2 of 8 (510 Views)
Re: ! Script Help Please - Linetype Replace
01-28-2013 01:15 PM in reply to: haynesc87
Hi............
I need the testing drawing (.dwg) file.......
you save the fiel.dwg  on "autocad2002.version"
please, you attach here (testing file.dwg)
Regards..
Active Contributor
haynesc87
Message 3 of 8 (492 Views)
01-29-2013 02:25 AM in reply to: haynesc87
I am working on Autocad Architecture 2010
*Expert Elite*
hmsilva
Message 4 of 8 (469 Views)
01-29-2013 03:34 PM in reply to: haynesc87
haynesc87 wrote
I wish to have a script that can be run on 1000+ drawings to do the following : Load a New Defined Linetype ..."NewLineType000" Select all layers that = NOT Continuous & = Colour 8 > Replace Linetype with "NewLineType000"
Chris,
save the following code a in a 'support' folder with the name of LayLt.lsp change the linetype name if necessary, and the .lin file name where the linetype is defined, in this case was in ACAD.lin
  (if
    (not (tblsearch "ltype" "NewLineType000"))
     (command "_linetype" "load" "NewLineType000" "ACAD" "")
  (vlax-for layer (vla-get-layers
		    (vla-get-activedocument (vlax-get-acad-object))
    (if
      (not (and
	     (= 8 (vla-get-color layer))
	     (= (vla-get-linetype layer) "Continuous")
       (vla-put-linetype layer "NewLineType000")
  (princ)
the following code was posted by EC-CAD, some time ago, and I changed it to run the above code.
the code will process the DWGs in a entire directory, save it as BatchDwg10.lsp, load it ad type
BATCH-DWG to run it
;; BatchDwg10.lsp by EC-CAD
;; To Batch Drawings..
;; Note: replace the Path/filename below to call up your Lisp
;;       to process the drawings the way you want.
;; Make sure your lisp program is in a 'support' folder ..
(setq my_lisp_file "LayLt"); Place your lisp here !
;; Load Supporting Functions
;; Old Version of 'BrowseForFolder' by: Tony Tanzillo
(defun BrowseForFolder ( Message / sh folder parentfolder folderobject result)
 (vl-load-com)
  (setq sh
   (vla-getInterfaceObject
       "Shell.Application"
   (setq folder
      (vlax-invoke-method
          sh
          'BrowseForFolder
          0
          Message
          0
   (vlax-release-object sh)
    (if folder
      (progn
         (setq parentfolder
           (vlax-get-property folder 'ParentFolder)
        (setq FolderObject
           (vlax-invoke-method
              ParentFolder
               'ParseName
              (vlax-get-property Folder 'Title)
       (setq result
          (vlax-get-property FolderObject 'Path)
       (mapcar 'vlax-release-object
         (list folder parentfolder folderobject)
     (if (/= (substr result (strlen result)) "\\")
       (setq result (strcat result "\\"))
       result
); defun
(defun C:BATCH-DWG ()
  (if (setq DirPath (BrowseForFolder "Select directory to batch drawings."))
   (progn
    (setq DwgList (vl-directory-files DirPath "*.dwg" 1))
    (setq ScrFile (strcat DirPath "batchme.scr"))
    (setq Ofil (open ScrFile "W"))
     (write-line "SDI 0" Ofil); Force Multi-Document mode
     (write-line (strcat "(setvar " (chr 34) "FILEDIA" (chr 34) " 0)") Ofil)
     (foreach Dwg DwgList
        (setq FullPath (strcat DirPath Dwg))
        (write-line (strcat "_.open " (chr 34) FullPath (chr 34)) Ofil)
        (write-line (strcat "(load " (chr 34) my_lisp_file (chr 34) ")") Ofil)
        (write-line (strcat "(setvar " (chr 34) "FILEDIA" (chr 34) " 1)") Ofil)
        (write-line "_.qsave" Ofil)
        (write-line "_.close" Ofil)
     ); foreach
     (close Ofil)
     (command "_.script" ScrFile)
   ); progn
  ); if
 (princ)
); function
 (prompt "\nType BATCH-DWG to begin the batch process:")
 (princ)
hope that helps
Henrique
Active Contributor
haynesc87
Message 5 of 8 (458 Views)
01-30-2013 08:59 AM in reply to: hmsilva
Hi Thanks for this
I tested it and the following is the outcome ....
01 - Layers which = Colour 8 & NOT Continuous where changed to "NewLinetype"
02 - Layers which = Colour NOT 8 & Continuous where changed to "NewLinetype"
03 - Layers which = Colour NOT 8 & NOT Continuous where changed to "NewLinetype"
... only outcome 01 is correct
Can you edit the script for me - its almost working
*Expert Elite*
hmsilva
Message 6 of 8 (453 Views)
01-30-2013 09:06 AM in reply to: haynesc87
try
 (if
    (if
     (and
	     (/= (vla-get-linetype layer) "Continuous")
  (princ)
 Henrique
Active Contributor
haynesc87
Message 7 of 8 (451 Views)
01-30-2013 09:07 AM in reply to: hmsilva
Life Saver
Thanks very much Henrique
*Expert Elite*
hmsilva
Message 8 of 8 (449 Views)
01-30-2013 09:09 AM in reply to: haynesc87
You're welcome,
Henrique
You are not logged in.
Announcements
Need installation help?
Ask the Community
